Minor alliteration aside, I noticed when I got the motor and mount from vacutug, I can't mount the motor first if I want to mechanically mount the motor mount to the hull. If I screw the mount to the hull, then trying to get the motor onto the mount means using a 90 degree screw driver in tight spaces. Lot's of people use epoxy to mount the mount to the hull after bolting the motor to the mount. Which epoxy is best or good for this? Epoxy covers a wide range of products.
