Need help choosing a radio system
Discussion in 'Electrical & Radio' started by mbf2002, Mar 8, 2019.
  1. mbf2002
    mbf2002 New Member
    New England
    Hi All,
    I am building out my first ship (a old swamp works USS Northampton/Houston kit) that I got 20 years ago. At that time, I had a 6 channel airtronics Vanguard radio that was converted to a surface frequency. That said, the batteries on it are blown and the charger is gone. I think it may make more sense just to scrap the old radio and get a modern 2.4 ghz system going.
    1. Any advice on what radio/receiver to buy? specific recommendations would be hugely appreciated I tried doing my own homework on this and started drowning in the terminology around transmitter modes/etc.
    2. Should I specifically get a waterproof receiver? again, specific recommendations greatly appreciated.
    Thanks for any and all help!
  2. Litch42f
    Litch42f Well-Known Member
    Nevada
  3. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    image.jpg image.jpg This is what I’m running. For what I spent it’s been great. I would suggest epoxy the receiver to water proof
  4. mbf2002
    mbf2002 New Member
    New England
    Thanks all! Why battery set up do you use to power the recover on this? I had the boat all wired up to run on 6v gel cell and wasn’t necessarily planning to switch my running gear to liPo or anything like that.
  5. Beaver
    Any 6v power source will work. 6v gel cell should work fine.
    ZARUBA1987 likes this.
  6. ZARUBA1987
    Tarkington Tx
    Yes your good to go with 6v
  7. GregMcFadden
    If I was buying today... Turnigy Qx7, smallest SBUS receiver I can get that supports telemetry (will tell you at TX if you loose signal) and run serial bus to clusters of servos.... cleans up the wiring a ton.
