I have my ESC hooked up with one battery. I have good steering, good forward speed but only one prop turns in reverse. What could be going on.
But I would guess he's got them wired in series. JK. If both motors are running fine in the forward direction, and only 1 runs in reverse, hum how does he do that. Start at the beginning. Not sure really, can you by hand rotate either motor and prop in either direction, and you feel no binding?
Just dont turn it on while you try to spin them it hurts, no realy it hurts, real bad sounds cool to if you can here it over the screaming []
Chuck: Maybe get rid of the esc and go with switches they are better and easier. give me a call i have some stuff you may need.
That is what I was thinking John, these ESC are turning out to be more of a pain then they are worth. I will give you a call after supper today.
Hey Chuck I have not had any problems with mine, maybe I could get a look at it before I leaved in july.
ESC's are fine. Just research and talk to the guys here on the forum who regularly use them. A lot of info has already been posted on the forum and their still there to check out.
