New to IRCWCC, Questions about Rules & Ships
Discussion in 'IRCWCC' started by PrepmasterNick, Jan 1, 2015.
  1. PrepmasterNick
    PrepmasterNick Active Member
    Lake Charles, LA
    i'm kinda spooked that my ship I just bought isn't listed: FS Foch. Hoping I can get contact from Wade and legalize it?
  2. Beaver
    That is a Suffren class isn't it. Should be legal. :)
    No, you're fine. Foch is listed under its class. It is a Suffren-class heavy cruiser, so look under Suffren. You get used to it :)
  4. PrepmasterNick
    Lake Charles, LA
    Sorry... still learning all the know-how. My bad
  5. Beaver
    Anybody can make an honest mistake. :)
  6. PrepmasterNick
    Lake Charles, LA
    I'll know what I'm doing on here someday
    As mistakes go, I wouldn't even count is as an official mistake. Still learnin', right? No biggie. Important thing is that you've got a ship that's okay to use.
  8. PrepmasterNick
    Lake Charles, LA
    Ya, no death star here
  9. Beaver
    Ya, looking forward to seeing another Suffren class being built. :)
  10. PrepmasterNick
    Lake Charles, LA
    Can't wait till I have this figured out so I can start the USS Baltimore kit I bought. The Foch is just my intro to figuring this out. Once I understand it and the hobby, I'm going straight into the Baltimore.
  11. Beaver
  12. Tugboat
    It'll be a study in contrasts... Foch has one prop and two rudders, and Balti has one rudder and two props!
  13. PrepmasterNick
    Lake Charles, LA
    Hmmm. This Foch has two rudders, two props, and a third shaft to mount a dummy prop or drag disk (not completely sure what a drag disk is)?
  14. Beaver
    Na, you want to power the center prop and leave the other two as drag props.
    A drag prop is generally a plastic disk on the unpowered shafts that creates drag. This makes is so you have to run the other prop at a higher RPM to get to speed. The higher RPM's makes more propwash over the rudders which helps turning. :)
  15. PrepmasterNick
    Lake Charles, LA
    Hmm.. Will have to do on the Baltimore
  16. PrepmasterNick
    Lake Charles, LA
    Are drag disks good, then? To have to run higher rpm?
  17. Beaver
    If I remember correctly, the Baltimore has four props. So you would power the two inner shaft and the two outer ones would be drag props
  18. Beaver
    Yes, they're good. They help with turning.
  19. PrepmasterNick
    Lake Charles, LA
    Thank you, sir! Anyway I can find out how close in or out they should be? Seen a lot of good 3d diagrams of ships but none with the prop shafts drawn looking from the bottom. confuses me.
  20. Beaver
    My best recommendation would be to get a good set of plans.
