Nikki's LST
Discussion in 'Warship Builds' started by NASAAN101, Nov 2, 2011.
  1. gunsnrosesx
    gunsnrosesx Member
    haha i like that idea. or if you get one of those remotes that dont have a long antenna. oh i always wondered what remotes the long ones are. what are they anyway?
  2. DarrenScott
    The short, simple version:
    Transmitters with the short antenna generally use the 2.4Ghz frequency band, the older type with the long antenna use 27, 29, 32, 40, 72 or 75Mhz, depending on which country you live in and if it's for ground or air usage.
    I'll leave the brain-melting, complicated, angst ridden, full explanation to those with more knowledge, time or both.
  3. NASAAN101
    Dave,
    The Radio That i have for my LST is a very old Futaba Attack 3 radio!!! But Its got the frequency maker on the top of the antenna and that's what i poked myself in the eye with, but i can't take it off! so i might just put some type on it so it not so pointy!!! bur all the looking that ive done, it seem as if this radio has been Discontinued!!!
  4. gunsnrosesx
    gunsnrosesx Member
    haha thats no good
  5. absolutek
    Theres nothing wrong with using a discontinued radio. Electronics aren't on the market for long before something newer is put out to replace it. If it works, use it.
  6. gunsnrosesx
    gunsnrosesx Member
    yea but my luck old stuff never works for me, i either spend alot of money just to get it fixed or i spend alot of money to buy a new one haha
  7. DarrenScott
    Exactly.
    I use an old, reliable, Attack 4 for my Liberty, and it's never let me down.
    Until recently HMS Rodney was operated with an equally ancient Flash 5.
  8. absolutek
    The transmitter I use for my 1992 Tamiya F1 Sauber Mercedes is over 20 years old. Still works great.
  9. NASAAN101
    Chase!
    I'm looking, But I'm looking at a three channel radio: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=12177, it's a HK-300 3 Channel 2.4ghz FHSS Ground Radio..
  10. NickMyers
    If the radio that came with it works, keep using it. Don't waste time and money replacing what isn't broke.
  11. NASAAN101
    Nick,
    I was thing for Later on!
    Niki
  12. KeriMorgret
    Seattle, Washington
    Nikki, worry about that when the time comes. What you're looking at now might be discontinued by the time your current radio fails.
  13. NASAAN101
    Keri,
    I'm just looking at the moment!!! I'm still going to use the radio i have for her, i'm just looking!
  14. gunsnrosesx
    gunsnrosesx Member
    Eh dont bother kuz as soon as you start looking your old radio will go bad, thats my luck anyway. but the others are right if it works use it its almost pointless to get another controler and waste the money if the controler you got works just as good.
  15. NASAAN101
    hey Dave,
    Did, you see this: But Its got the frequency maker on the top of the antenna and that's what i poked myself in the eye with, but i can't take it off! so i might just put some type on it so it not so pointy!!!
  16. NASAAN101
    Hey Guys,
    Dose anyone know how to get glue gun glue on the inside of the hull! The motor mount she had in her when i got her was old and Rusted, so i made my own, but The guy I got her from Use glue gun glue and I have no Idea how to get that off!
  17. gunsnrosesx
    gunsnrosesx Member
    heat it up or cool it alot, i peel my glue gun glue right off usually its never a problem for me, but if it comes down to the worst acetone works good gotta let it soak for about 4-5 min but be careful will damage finishes and paint.
  18. NASAAN101
    the problem there is, you can't get a hair drawer that hot!!! I would if i glue gun would world work??? Or would it damage the hull??
  19. gunsnrosesx
    gunsnrosesx Member
    what about a heat iron?
  20. NASAAN101
    Dave,
    I only have Four inches across to play with!
