Noobie Warship Suggestions
Discussion in 'Ship Comparison' started by AdmiralBangerBang, Jan 15, 2018.
  1. AdmiralBangerBang
    AdmiralBangerBang Active Member
    Long Island
    Yeah but suggestions?
  2. NickMyers
    The most beautiful ship you will ever see is that which you make yourself, even if it has a superstructure that only a mother could love.
    rcaircraftnut and WillCover like this.
  3. AdmiralBangerBang
    Long Island
    Yeah, OK, but still, suggestions please?
  4. NickMyers
    Kirov
    Suffren
    Seydlitz
  5. AdmiralBangerBang
    Long Island
    What about Iron Duke, Lion, and Kongo? Could I build those?
  6. NickMyers
    They look like hideous gutter beasts, must have been drydocked on keel blocks from the ugly tree
    S.macd and WillCover like this.
  7. AdmiralBangerBang
    Long Island
    OK sure, but can I build them? Are they beginner friendly?
  8. aleMI
    aleMI Active Member
    Inland Empire, California
    HMS Lion is probably the best in your list. It's a little long, so turning won't be as good as shorter ships, but it has two rudders which helps. 4.5 units, so 3 guns, doable for the beginner. I'm assuming you'll be getting help with this hypothetical build from vet battlers.
    One thing to consider is hull availability. For example, Strike is out of stock of the Kongo hull, so I'm not sure if there's a way you can get one unless someone has one lying around.
    Also battlecruisers will be a little more expensive then a cruiser. Though you do get sidemounts.
  9. AdmiralBangerBang
    Long Island
    HMS Tiger? Also, I'll be scratch building this boat with help from Barry.
  10. aleMI
    aleMI Active Member
    Tiger is very very similar to Lion. Pretty much the same length, has 4.5 units and two rudders as well. Even has the same speed.
    If you're willing to scratch build hulls then the Kongo would be an option. It's also very similar to tiger and Lion.
  11. AdmiralBangerBang
    Long Island
    How good are they in combat? and where can I get plans?
  12. aleMI
    aleMI Active Member
    Plans for Lion Tiger and Kongo can be bought here: http://www.strikemodels.com/products/ship-plans/
    You'd have to ask more experienced battlers on how good or not they are. Ask Barry too. Personally I think you'll be fine. It's more important to like what you build. None of your ships you listed are terrible.
    An example of a not so good combat ship is the Alaska: very very long, and single rudder so bad turning. Bigger ship= bigger target too.
  13. AdmiralBangerBang
    Long Island
    Yeah, I hate the Alaska. It's like my former crush. Good looking but fricking worthless.
  14. aleMI
    aleMI Active Member
    I debated getting an Alaska but bought a different ship for that reason. I have battled a borrowed Scharnhorst, which has a better turning ability due to it's two rudders. An NC and SD easily out turned the Scharnhorst during battle. I shudder about what would happen with an Alaska.
  15. AdmiralBangerBang
    Long Island
    Does Strike still sell plans? It's shutting down.
  16. aleMI
    aleMI Active Member
    They will continue to sell plans. They mentioned that on their site.
    KeriMorgret likes this.
  17. AdmiralBangerBang
    Long Island
    OK! Oops. Can't read today for some reason.
  18. aleMI
    aleMI Active Member
    That's fine. We're here to help. If you haven't done so I recommend starting taking notes too, so you have a clear understanding of what to do next.
  19. rcaircraftnut
    Oklahoma
    My particular DKM Scharnhorst turns quite well, so well that the fishtail rudders I run are now voted out but my set are grandfathered in hehe.
    aleMI likes this.
  20. aleMI
    aleMI Active Member
    Interesting. I mean with two rudders it shouldn't be a bad turner. Probably because I was against veteran battlers with well designed NorCar's and SoDaks!
