Novik destoyer
Discussion in 'Ship Comparison' started by HMTOlympic, Oct 29, 2012.
  1. HMTOlympic
    HMTOlympic Member
    im thinking of building the russian destoryer Novik launched in 1910 but idk how early the rules will let me go as far as the year the vessle was launched.
    1910 is legal in pretty much every ruleset except Age of Sail.
  3. Anachronus
    Where did you find the plans for her?
  4. absolutek
    I found them online pretty easily. Looks like a fairly challenging build if its in 1/144.
  5. HMTOlympic
    HMTOlympic Member
    where did u find them ive just been looking at actual designs and scaling it down
  6. Anachronus
    Aren't they around 1,100 tons displacement? Circa 3 lbs?
  7. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    I like this little destroyer. I found plans online, copied, enlarged, and adjusted them. I think it would make a great 1/144 ship. One rudder, one powered prop, should be able add 3/8" or so to depth of hull and stay within limits. I built a 5lb Capitani Romani with almost 1lb to spare. It has two motors and torp setup for "Big Gun".
    EDIT: I believe the weight is going to be about 1lb built with scale draft. About 3 lbs at 1/96 scale.
  8. Anachronus
    I am getting my formats mixed again. Senility attack.
    Doable but tricky. Would at most mount a single-shot spurt gun from an accumulator. Sounds like something I would do to prove I could. :)
    If you do it, Ben, check the Orfey builds in the build forum. If you have questions, I'd be happy to help. But it WILL be tricky :) If you'd like to do a Russian cruiser instead (a bit easier but still small and cool), I have free plans I can email you.
  10. HMTOlympic
    HMTOlympic Member
  11. Tugboat
    I have plans for Novik 1911, probably same ship with a few minor mods.
  12. Anachronus
    Novik is the prototype for Othar.
  13. Tugboat
    She actually weighs a hair more (2.56# max model weight in MWC), and has 3 shafts vice 2, which makes her better for our purposes, since you can just drive the center shaft and have two drag props! :)
  14. absolutek
    I can't remember where I saw the plans, but it was from one of the Polish Plans services for model makers (not profile morskie).
