Oil lite bushings
Discussion in 'From Stem to Stern: Warships In Detail' started by Sinkazuki, Apr 5, 2019.
  1. Sinkazuki
    Sinkazuki Active Member
    Colorado
    Is anyone still using these in their shaft tubes? I wonder if they last longer than soldered up tubes
    Randy
  2. Kevin P.
    I use them, I get them from McMaster in all sorts of shapes and sizes, I think they are pretty standard in the northeast at least
  3. thegeek
    Mc master has the best price/selection.
    10 pack for cheap. Pop them out when they get oval, slip in a new one and you are new again.
  4. Sinkazuki
    Colorado
    Part number?
    Thx
  5. thegeek
  6. Sinkazuki
    Colorado
    Thx Carl.
    If using the bearings do you still grease the shaft?
    RANDY
  7. thegeek
    Yes I will lube it generally .
    I use the green long life stuff in a big cartridge from Lucas. Tractor stuff.
