1/144 Oktyabrskaya Revolutsiya 1.0
Plans to build the bulged version of the Russian Gangut battleship
  1. rcengr
    rcengr submitted a new resource:
    Oktyabrskaya Revolutsiya - Plans to build the bulged version of the Russian Gangut battleship
    WillCover likes this.
  2. Beaver
    Perfect timing, Mark! Gangut is next on my build list. :)
  3. bgt0990
    bgt0990 Active Member
    Showing my ignorance here. If I take this PDF to Staples\Kinkos and ask them to print full size I will end up with a correct size plan?
  4. rcengr
    Correct - print at full size - make sure they don't click that scale to paper size box.
    Anachronus likes this.
  5. kgaigalas
    kgaigalas Well-Known Member
    Grand Rapids, Michigan
    rcengr
    Hope you can make our May 26,27 battle, or just come visit.
    We can get you a boat. :):):):)
  6. bsgkid117
    Hey there, a local rookie is building this and we had some questions. The ribs stop at the subdeck, is that the casement deck? If so wouldnt the subdeck in its position be illegal?
  7. rcengr
    Not in Treaty, but possibly in your rule set. As a minimum you need a stringer where the sub-deck is or you can't build the casements inboard of the hull.
