One for the motor gurus.
Discussion in 'Propulsion' started by Captain obvious, Sep 13, 2016.
  1. Captain obvious
    Captain obvious Active Member
    Hastings, MI
    I was looking through amazon.com trying to figure out what motor to put in which hull of the hulls that I have. And questions came up in my feeble mind.
    1. Which motor should I get?
    2. How does the number of turns effect the motor?
    3. Can any motor be wire so if there are a pair of them they counter rotate?
    4. Brushed or Brushless?
    5. With or without heatsink?
    6. 1 esc per boat or 1 per motor?
    7. What about gear boxes? I saw some at hobby king that had gears connected already. Thoughts?
    I am sure I will come up with more but that is a start.
    To give a little background I have a liberty ship that I am refitting after sitting in storage for about 1o years. I have a Moggy that I just purchased. I am planning on an Italian cruiser and in the distant future I have a NC that was fitted out as a big gun battle wagon. I will probably have to do something simple for my kids so they are included as well. I have built before but my motor controls where a radio shack motor, servo and a pair of micro switches.
  2. rcengr
    You need to decide brushless or brushed before most of those questions can be answered. That decision mainly comes down to personal preference. So get started by reading through the "Brushless 101" thread, it should answer some of your questions if you choose a brushless set up.
  3. Captain obvious
    Hastings, MI
    I was thinking brushed because that is what I am familiar with but what are the advantages of brushless?
  4. SteveT44
    Better power to weight ratio but at a cost of added complexity, higher amp draw, and increased fragility.
  5. SnipeHunter
    Meh, complexity is similar in many setups but at the simplest level brushless are more complex, at the level many people use them complexity is comparable. (ESC + brushed motor vs ESC + brushless motor)
    In my experiences (battling since 2002, brushless since 2012) amp draw is lower for the same performance and durability is higher for brushless.
    Doing a good job setting up the system is way more important than which you choose to use.
    Also use a gear box, yes it is more complex, costs more, and take up space, but the extra torque and adjustability are worth it. Our props aren't designed to run at ungeared motor speeds.
  6. Captain obvious
    Hastings, MI
    Need to worry about space so I am not sure that a gearbox is possible.
  7. kgaigalas
    kgaigalas Well-Known Member
    Grand Rapids, Michigan
    Brushed motors will be powerful enough for a small boat
    I run my Invincible with 2 brushed / 2 gearboxs and no ESC
  8. Captain obvious
    Hastings, MI
    How did you adjust speed?
  9. kgaigalas
    Gears.
    Also my boat never failed from a bad ESC
  10. rcengr
    I disagree that gearboxes are needed with brushless motors. Low KV brushless outrunners have plenty of torque. I've run a 2 1/4" prop direct drive on a 96 scale Hood that was over a 100 pounds. It would actually make speed (34 sec) with only one motor running.
  11. Captain obvious
    Hastings, MI
    New question, if I was looking to have higher torque would it be more beneficial to run a single motor with a gear box or dual motors with a single output? Looking to run just a single prop. This is not for my moggy project but for something completely different.
  12. SnipeHunter
    You'd be using a gear box either way, so two motors on a gear box will give more torque than one motor.
    Having run 2 motors to 1 shaft in the past I prefer a properly sized/selected single motor. You can get more than enough torque with the right motor/gearing, no need to double that up from a cost/complexity standpoint.
  13. Captain obvious
    Hastings, MI
    What is a good place to pick up gears for an NC and what tooth count should I be looking for?
