One motor Two Props.
Discussion in 'Construction' started by Admiral Where Did He Go?, Jan 8, 2017.
  1. Admiral Where Did He Go?
    Admiral Where Did He Go? Member
    Petite Riviere, Nova Scotia
    Hello all............. I have something to ask.......
    do you know if there is a gearbox that only uses one motor but uses two props. (would like to have for my Lutzow :)). If so please let me know were or how to make it.
    Thanks
  2. NickMyers
    BattlersConnection has one.
  3. Admiral Where Did He Go?
    ok thank you Nick :)
  4. Beaver
  5. Admiral Where Did He Go?
    perfect now all I need is some money to get it lol :laugh:
  6. SteveT44
    Cheaper to put two motors in.
    Tugboat likes this.
    And with two motors, you can splay them apart and put the pump further aft. Alternatively, you can reverse the side that the motor sits on the gearbox, and put the pump right up against the gearbox.
  8. Admiral Where Did He Go?
    but what I want is to have more space inside ....... Two motors is a good idea only it takes up space.
    one motor with a gearbox will not take up as much space.......more room for guns or a bigger pump.:D
  9. SteveT44
    Not really. As Tuggy stated, spreading the motors apart frees up center line space (where the cannons and pump have to go).
    Here's an example:
  10. Admiral Where Did He Go?
    OH that's what he was talking about....silly me.... but with two motors don't you need two ESC or can they both run off one?......
  11. NickMyers
    two esc if brushless. one esc (sized right) if brushed motors
  12. Admiral Where Did He Go?
    another Question doesn't that use up a lot of battery life too have dual motors??
  13. SteveT44
    Not really. Your boat will have a max speed which equates to a specific watt value to reach and maintain that speed. Using one motor or two, the watt usage will be the same, just spread across one or two motors. FYI, no gearbox is 100% efficient so there is some power loss when using one. Damned things are also noisy as hell. I prefer a whisper quiet boat for sneak attacks! ;)
  14. Admiral Where Did He Go?
    ok...good to know....would you have to Solder the wires from the motor together so there is only two going to the ESC...and what size of a ESC would I need to use for it. I have a few from the Trucks (racing:D) that are brushed encase I needed them don't know if they will work or not (china crap :() and their getting old. should be "waterproof" still :p.
  15. SteveT44
    What motors are you using?
  16. Admiral Where Did He Go?
    dynamite 20t or 15t depending on the size of the 15t when I find it.
  17. SnipeHunter
    Do you have any crawler motors, those would be better for drive, save the low turn motors for the pump.
  18. Admiral Where Did He Go?
    no I don't but should be able to fine some at my local hobby shop.;)
  19. SteveT44
    I'd highly recommend that you get a class 3 hardware kit from either Strike or Battlers Connection. Besides the correct motors, you get props, shafting, rudders, etc.
  20. Admiral Where Did He Go?
    class 3.....il look into it.:)
