Painting new boat
Discussion in 'Construction' started by Volkswagen50, Sep 1, 2018.
  1. Volkswagen50
    Volkswagen50 Admiral (Supporter)
    Are there any paints to avoid using for new construction? I went through about a dozen threads and didn't find anything about brands or types of paint to use. Is exterior latex alright? Sorry if it sounds dumb, but I do want to get it right and there are plenty of choices.
  2. djranier
    People have been having issue'a with the drop test when using exterior latex paints. The spray enamels seem to work best.
  3. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    NEVER use Rust-ol lem!!! However it is spelled!! It seems to turn into some sort of vinyl.
    Volkswagen50 likes this.
  4. SnipeHunter
    Regular latex paint in the little sample jars from home Depot/lowes has always worked great for me. Get any color you want to.
    I'd stay away from liquid enamel paint.
    Spray paint seems to work fine to.
    Nate G likes this.
  5. Z Boat
    Z Boat Well-Known Member
    Roseville California
    Get Flat sample jars as stated above. Cheap!!!!!!!
  6. NickMyers
    I paint mine with craft acrylic. Works well and doesn't make a hardened skin. Been meaning to try @SnipeHunter's suggestion.
  7. Z Boat
    Any color you want and flat will not add strength. I have been using it four years now. Just spray a clear coat and it will wipe down.
  8. Volkswagen50
    Thank you one and all. I've got several options already from what was listed, so I should be all set. I've been buying small sample paint at the local hardware store for the last year or so from the goof shelf of discount paint. Mixing should get me the colors I need.
  9. Bob Pottle
    In the early days of NABS a Northampton skipper painted his ship with an epoxy based paint. Took us a while to figure out why we weren't able to get any penetrating hits on it!
