Plan resizing/scaling
Discussion in 'General' started by jstod, Jan 22, 2014.
  1. jstod
    How do I take the tif file from here: http://usuarios.arsystel.com/naviost/nst/I-planos.htm (its the first file) and get them to scale at 1/48?
    Any help would be greatly apperciated :)
    Thank you!
    Jon
    You go to www.gimp.org and download the GIMP (GNU Image Manipulation Program) for free, and open the file with it. Then, from the command bar at the top, click on Image, and down towards the bottom of the popup menu that opens, click on 'Scale' then choose 'percentage', and type in the percentage of enlarging that you want. And then tell it to do it. DO IT NAO!
  3. jstod
    Thank you! ok I am downloading now. the site says the current scale is 1/75 whats the percentage I need to type in? sorry my brain has decided it does not feel like remembering how to figure that out.
    52.1%
  5. jstod
    Roger that thank you
  6. NickMyers
    Current scale is 1 / 75, desired scale is 1/144, consider x to be the value needed to transform from 1/75 to 1/144. Solve for x
    (1 / 75) * x = ( 1 / 144 )
    x = ( 1 / 144) / ( 1 / 75)
    x = ( 75 / 144 )
  7. jstod
    Ah thats what it was. haha The only difference is for this ship the desired scale is 1/48 :)
    thank you!
  8. Remo
    Remo New Member
    Also it might be a good idea to draw a ruler in the image that you can measure once printed to check that it all scaled to plan.
    156.3% in that case. Been a busy (crappy) day, wasn't thinking sailing vessel...
  10. NickMyers
    Wow, I don't know how I didn't notice that you said 1/48th as well. Sorry about that
  11. jstod
    No worries the formula should still work :) This ship is going to be huge if I ever get her off the planning table and under construction. something like 4 ish feet long (not that long) and over 1 foot wide and the hull without masts will be over 1 foot tall from scale keel to deck. Not counting the extra keel I intend to add for stability reasons.
  12. bgt0990
    bgt0990 Active Member
    I'm looking at the PDF plans of the GOLO. Most are listed as .015 / meter. I am getting all twisted trying to make this conversion.
    .015/m = 1.18"/39.37"
    Where do I go from there? (been 50+ years since I learned any fractions) Eventually I want 1/144.
    Any help?
    Thanks
    Barry
  13. Tugboat
    If nobody does the math before lunch, I'll get to it then :)
  14. bgt0990
    Thanks Tug, If you can show me the steps it can help clear up a lot of things.
  15. Tugboat
    In a hurry so no time to explain it, but increasing it by x2.16 should do it. I think.
  16. NickMyers
    think you have to downsize by Tug's number..
    0.015 : 1 is a larger scale than 1 : 144, it is somewhere around 1 : 66
    (0.015 / 1 ) * x == (1 / 144)
    x == (1/144) / (0.015 / 1 )
    x == 1 / (144 * .015)
    x = 1 / 2.16
  17. bgt0990
    Thanks guys it's beginning to make some sense.
  18. __Titan__
    __Titan__ Member
    Minnesota
    I know this thread is kinda old but I was looking it over and I have my own sketch and I was wondering how you print out a 65 inch by 5 inch picture on a regular printer. I know I have to break it up but what’s an easy way to do that?
  19. SnipeHunter
    Pretty much every printer I've used will automatically print it on multiple pages and then you can line it up by hand/eye pretty easily. You might have to mess around in your print settings but it should be pretty straight forward.
