Pocket Battleship Deutschland
  1. JustinScott
    JustinScott Vendor
    My plan of attack:
    - go 1:1 gears first since it’s the easiest
    - print new props with an aggressive pitch
    I have to believe the 380s are fast enough, there is something else wrong here.
  2. JustinScott
    JustinScott Vendor
    It’s a 3-7/8” buna rubber o-ring. I watched your video about recovering after ship2ship impacts. ;)
  3. JustinScott
    JustinScott Vendor
  4. Beaver
    She's still way below fast gun speeds. I think you need bigger or better motor.
    diceman42 and bsgkid117 like this.
  5. Commodore
    Commodore Well-Known Member
    Sunny TX
    Eh, I'm not so sure about that, it seemed as though there were a couple of times there where it picked up some speed. Might have been cavitating or something.
    diceman42 and Boatmeister like this.
  6. JustinScott
    JustinScott Vendor
    You’ll see it live on Saturday. We can have a race! ;)
  7. Commodore
    Sunny TX
    Careful what you ask for - by the way, do you have an address we can plug into the ol' phone/gps for the location? 11AM, I presume???
    I'm pretty much planning on bring a bote of some sort that will hopefully move and tootle around some. Mostly just a shakedown/show off kind of thing. We'll see.
    (I'm going to be up late enough as it is helping someone else get their bote together, so there is that.)
  8. JustinScott
    JustinScott Vendor
    McInnish Park
    Ball Park Way
    Coppell, TX 75019 United States + Google Map
  9. Commodore
    Sunny TX
    Well, so far we've managed to set one boat on fire. We'll see what else we can manage tonight.
  10. JustinScott
    JustinScott Vendor
    Oh no!? Really?
  11. Nomercy
    Nomercy Well-Known Member
    Maryland
    Did that last weekend
  12. Nomercy
    Maryland
    Kevin P. and JustinScott like this.
  13. Commodore
    Sunny TX
    Welp, had a fun afternoon with the NTXBG folks today. I might have accidentally introduced them to Seydlitz. Oops.
    Anyway, it was a nice day, we weren't at work, we were at the pond, playing with botes. Good times. :)
    Hopefully Justin will post some video later. I'd post a pic or two, but that probably wouldn't be polite - one of the fellows was nice and let me shoot him. Yay!
    (I'm afraid I, well, Seydlitz, you know.)
    JustinScott and Justin Ragucci like this.
  14. JustinScott
    JustinScott Vendor
    Battle highlights!!
  15. JustinScott
    JustinScott Vendor
    Deutschland had her first showing on the lake, along with her sister ship, Guilio Cesare.
    Sadly, as we prepared to take video of the two ships triumphantly sailing together in their first battle, one of Deutschland’s motor burned up. Fortunately, I did program a remote kill switch for either motor; so she was able to return to port under her own power. The motor was found to be defective & both ESCs are still in good working order.
    @Commodore traded me for some new faster motors, so I expect this will turn out to be a positive.
  16. Iunnrais
    Iunnrais Active Member
    Texas
    Bismarck v Seydlitz on one side with live guns and Richilieu v Lutzow playing some bang bang and just having fun driving around. Was a good day. Enjoyed meeting and hanging out with the NTXBG guys.
    diceman42 and Wmemlo like this.
  17. JustinScott
    JustinScott Vendor
    UPDATE- I spent time on the cannons over the last few weeks. Most noteworthy, I finally have an answer to reliable printing.
    The major issue has been the chamber bolts at the bottom of the cannon continuously printed poorly. I’ve since moved away from vertical mounted piston-action. This let me move the chamber bolt to the side of the cannon. After that @Commodore & @Huru MorDae pointed out a layer-height vs thread issue, and voila perfect threads!
    Everything is looking good on my bench fit; so I moved forward to acetone vapor bath (tonight). I’m looking forward to the result!
  18. Kotori87
    Justin, I changed my cannon treatment process a while ago. A vapor bath by itself was not always enough to seal every single layer, so nowadays I spent several minutes brushing the outside of my cannons with acetone. This seals it very well, since the brushing fills in the layers much more effectively. However, it ends up leaving streaks and dribbles which look ugly, so I stick it in my vapor bath for about 10 minutes. This clears up the streaks and dribbles nicely, so the cannon looks as nice as it works. Ultimately that means the acetone bath is purely cosmetic though, since it's the acetone brushing that does the actual sealing. Also, I have to be very careful to protect any threads from the vapor bath, otherwise they will get melted and stop working.
  19. JustinScott
    JustinScott Vendor
    Thx!
    thx! How long did you soak in the vapor bath?
    I thought about the threads too…. How did you protect the threads?
  20. Kotori87
    I have a giant glass jar from Walmart that I lined with paper towels. The paper towels soak up some of the acetone and cause a wicking effect. This makes the vapor bath denser and taller than otherwise possible. I do not heat the vapor bath at all, as hot acetone is potentially very dangerous. Instead, it's a room-temperature vapor bath. I put cannons in for about 10 minutes each. Superstructure bits go in for longer since they don't get brushed first. I put my parts on thin brass plates, since I had them available and they don't soak up acetone or otherwise mess with the process.
    All of the threads on my cannons are regular machine threads like 1/4-20 and 1/8NPT so I just plug them with metal parts. Your cannons use non-standard threads so I don't know what you'd have to do. Maybe put some masking tape inside, or print some plugs in a different plastic that isn't soluble in acetone? Or maybe it doesn't need protection. Coarse threads with simple shapes may not be affected much by a short vapor bath.
