Pocket Battleship Deutschland
  1. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    Add a channel to the stringers so you can put ⅛” round bar as an impact surface. The plastic is not going to be terribly strong between the ribs and having that little bit of metal serving as an intermediate surface can save the stringers from being destroyed.
  2. bsgkid117
    What he said, plus:
    That little notch where the deck step is has returned! lol
  3. JustinScott
    JustinScott Vendor
    got it. Thx!
  4. JustinScott
    JustinScott Vendor
    Damn notch!
  5. Commodore
    Commodore Well-Known Member
    Sunny TX
    Just a suggestion - that box behind the deck step - make it a separate piece attached to the lower deck, so it's removable. Having large portions of the deck occluded like that can be a nightmare when having to work on things, because inevitably *something* fiddly wants to live in the spot underneath the non-removable part.
    darkapollo and JustinScott like this.
  6. JustinScott
    JustinScott Vendor
    Progress!
    So far, the printer configuration is slowing me down the most.
  7. JustinScott
    JustinScott Vendor
    Cannon progress!
    https://youtube.com/shorts/CtQPvZeumzo?feature=share
    It's interesting that when the co2 "bottle" is mostly full the cannon typically fires one round only.
    Once it's nears the end of the bottle, it fires multiple rounds more often.
    I think this makes sense, since it uses a pressure differential to push the piston & keep the next round out of the chamber.
    I can tell this cannon hits a LOT harder than the Surcouf cannon. I think the more refined 3d printing techniques are giving better layer adhesion.
    Next steps, I'm finally ready for an acetone vapor bath. This should keep the co2 from seeping out. Which should let me run well at lower tank pressure.
    After that, I'm ready to try ball bearings. Everything in the cannon is sized for 7/32", just like Deutschland expects. ;)
    Lastly, I need a full sized bottle and regulator!!
  8. JustinScott
    JustinScott Vendor
    I took a break from all the frustrations of printing the hull; to print the superstructure!
    Mark41 and darkapollo like this.
  9. Commodore
    Sunny TX
    Looks nice!
    JustinScott likes this.
  10. JustinScott
    JustinScott Vendor
    thanks! Looking forward to seeing it all shot to hell! :)
  11. JustinScott
    JustinScott Vendor
    Update - first fitting of the bits & pieces.
    I’m still not happy with the print quality; but I’m happy with “most” of the fit. I do have to move the rotate servo bc the CO2 bottle is larger than expected.
    C226B0D1-B2A8-489F-87B7-A7291A422D31.jpeg CFBA9644-E54B-4CAC-845C-8690BBDC1475.jpeg 17B30E9F-984D-4B67-98DE-1841825E3F42.jpeg
  12. JustinScott
    JustinScott Vendor
    More photos…
    Leland, Mark41 and Boatmeister like this.
  13. Commodore
    Sunny TX
    You might want to rework your CO2 bottle mount so that the regulator is a bit higher. You really don't want to be sucking liquid CO2 into your lines.
    Otherwise, looking pretty good so far!
  14. Terry Keef
    Terry Keef Member
    Conway, Arkansas
    Love the printed superstructure. Much nicer than the old scratch built on the Admiral sheer.
  15. JustinScott
    JustinScott Vendor
    Thank you!
    That’s what the mounting bracket underneath the neck will be for! Just need to design and print something that matches and elevates the bottle neck. ;)
  16. JustinScott
    JustinScott Vendor
    Thanks!
  17. darkapollo
    Carlisle PA
    Quick question. Where are you measuring the waterline from? On the Deutschland class, the waterline was not at the bulge.
    I ask because yours has a lot more 'meat' on the bottom than mine. I have less than 1/2" of solid area from the bottom of the hull to the start of the windows. I know BigGun has different build rules, but if you are measuring from the top of the bulge, you are about 3/8" too high for the typical 1" below waterline.
    I actually just imported your sketch into my build, calibrated it to 3" between ribs and yes, you seem to be measuring from the bulge.
  18. Commodore
    Sunny TX
    I can't speak directly to the waterline, but ... oh, wait, maybe I can. What I was going to say is that it will probably take an iteration or two to work all the issues out anyway. Things like waterlines and hard area boundaries can be fiddled with on version 2.0, etc.
    So, Swampy hull: 1.6" freeboard amidships
    Scratch wood hull: 1.5" freeboard amidships
    Make of that what you will.
    JustinScott and darkapollo like this.
  19. JustinScott
    JustinScott Vendor
    I’ll take a look at it. I had forgotten the whole waterline rule in IRCWCC
  20. JustinScott
    JustinScott Vendor
    Progress on the rudder!
    Boatmeister and Beaver like this.
