Photos Pre-dreadnaught mania
Discussion in 'Photos & Videos' started by froggyfrenchman, Dec 2, 2013.
  1. rcengr
    I'm using a 0.25mm layer for most of the part. This is my new default "coarse" setting, since it is easier to remember to draw parts in increments of 1/4 mm heights. You can see that the tops of the secondaries look pretty smooth: I changed to 0.1mm layers just for the top surface of the turret. Normally I use 2 or 3 top layers, but when going down to the 0.1mm layers I had to change that to 5 or 6 layers to avoid voids.
    I'll post the files for these soon. I made some changes to the Liberte secondaries and I want to do a test print before I post them. However, I tore the printer down for some upgrades this weekend, so it will be a couple more days before I can print again.
    Yeah, the Ormerod's hot end is all tore apart due to a jam. Grrr.
  3. Kotori87
    There's only one place that jam belongs, and the nozzle of my printer is NOT it. Good luck getting yours un-jammed, Tugboat. I had to get a special set of drill bits to fix mine.
  6. rcengr
    Looking good. Are they going to make the water next week for a shakedown cruise?
    Currently it looks like they may run sea trials only. I do not think I will be able to get them battle ready in time. So hopefully we will get some photos of them on the water.
    We were able to get the two new ones on the water for sea trials yesterday.
    Vance has decided that he likes the Republique. So I get to keep my Danton.
    Beaver, NickMyers and absolutek like this.
  9. Anachronus
    Vive la France!
    froggyfrenchman and absolutek like this.
  10. frank falango
    frank falango Member
    sebring florida
    where can I get the plans in our scale I have the lazer cut kit &3d printed s/s/
  11. NickMyers
    @rcengr (Mark) designed all the parts and kit for the Potemkin, he should know what needs knowing.
  12. frank falango
    sebring florida
    just need to know how tall is the 01 deck is I can figure out the rest
  13. NickMyers
  14. rcengr
    If you click on the kits hyperlink in my signature and scroll down to the Libertie, there is a hyperlink there to PDF plans.
  15. gunner250
    gunner250 Active Member
    Missouri
    Such beautiful ships.
  16. NASAAN101
    And tiny :)
    I really like these ships. I could see Fleets of these in RC Combat with just the PredDreadnoughts battling only.
    froggyfrenchman likes this.
  18. mike5334
    Good to see another Liberte (Verite) on the water. :)
  19. froggyfrenchman
  20. froggyfrenchman
    Another one of Mark's kits. The French Henry IV.
