Project Atlanta - Fastgun CL
Discussion in 'Warship Builds' started by SteveT44, Oct 27, 2017.
  1. Anvil_x
    Hey what diameter magnet are you using there?
  2. SteveT44
  3. SteveT44
    The pump mount is sorted out. The pump will get wire-tied to that side support. The three washers glued to the bilge hold the bottom of the pump in place.
    UPDATE: Thread on this pump
    The bottom plate of the pump was trimmed down and channels added to improve water flow.
    Dog screen filter
    Now that the pump is placed I can finish up the water channeling in the aft end.
    Till next time...
  4. Lou
    Steve,
    No issue with the outlet being off center? I know on mine when the pump was under load it would tend to submerge the outlet under water.
  5. Beaver
    Steve isn't figuring on pumping enough water for that be an issue. No holes - no water - no pressure, right Steve? ;)
  6. SteveT44
    I don't know. This is basically the same setup I have in my Mogador and I haven't noticed that issue. If it is a problem, I'll put a deflector over the outlet directing the stream aft. This was the simplest mounting solution so I went with it.
  7. SteveT44
    You have discerned my strategy. Using the lighting quick reflexes of youth, I will teach my grandson to drive around, over, under, and in-between any and all bb paths's, thus avoiding holes in the hull. I don't know why I even bothered to put a pump in this thing? :woot:
  8. Beaver
    Yes, that's a very good strategy! No bbs will get you down there. No pump needed either! :laugh:
  9. NASAAN101
    Steve,
    my plan is to have my dido ready by spring, and your grandson and i can run together! Or go one on one and let him sink me.
  10. Bob Pottle
    That's a really innovative build!
  11. SteveT44
    Looking forward to it Nikki
  12. NASAAN101
    I just hope we have Regional in april!
  13. SteveT44
    Back to cutting foam water channeling.
    The pump sump is done...
    ... and shaft alley is complete. FYI, a course rat-tail file cuts nice grooves in this yoga block foam.
    The channeling further aft will have to wait until I get the cannons sorted out. Now I'm onto controls and wiring.
    dietzer likes this.
  14. SteveT44
    Thought I'd do a schematic for once...
    dietzer likes this.
  15. Beaver
    Don't the BC firing boards have the diodes already in them?
    I really like the Polulu boards, they're dirt cheap and they have the diode built in.
  16. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    "Don't the BC firing boards have the diodes already in them?
    I really like the Polulu boards, they're dirt cheap and they have the diode built in."
    Newest ones do but the older ones do not.
  17. SteveT44
    I'm using the BC XR-4D board. It does not have onboard diodes. The Pololu boards are nice, I use one in the Mogador, but they don't have a dual-on-one-channel solution.
  18. dietzer
    dietzer Admiral (Supporter)
    I think you are convincing me to switch to 24V. What solenoids are you using for 24V operation?
  19. SteveT44
    Welcome to the dark side! ;)
    In the Barham I'm running 12v Kip's ate 24v. Working great so far. For this build, I just picked up some Spartan 24V valves to fool around with. I have extra 12v coils that I may swap out with. Need to see which coils fire with greater authority at 24v.
    FYI, almost all of the Spartan valves are available off the shelf in 24v at USPlastics.com. Though their only 1.5mm orifice but I think they can be enlarged easily enough. Stay tuned on that project.
  20. SteveT44
    Started on the cannons. This is going to be an interesting installation.
    dietzer likes this.
