Prop question
Discussion in 'Propulsion' started by Captain obvious, Oct 27, 2016.
  1. Captain obvious
    Captain obvious Active Member
    Hastings, MI
    Simple question. Looking for quick acceleration and battery efficiency. 3 or 4 blades and shallow or steep angle?
  2. thegeek
    They don't go hand in hand. To get one you generally have to give up the other. 4 are better than 3, shallow requires more RPM, steep less RPM more torque (brushless better for steep). Get to a build in your area and bring a camera and note book.
  3. Bob
    Prop Shop in the UK makes excellent props. I like the kort nozzle style. Others like the steam scale. Brass props are better as the blades don't fall off.
  4. thegeek
    Brass props typically are soldered to a hub and will fail when you crunch them on a rock (one blade at a time). Bronze cast props from UK prop shop are pricey but will hold up to extreme abuse.
  5. Bob
    One set of Prop Shop Props is the same cost as two soldered prop sets. You need to have two sets so when the blades fall off you have a back up.
  6. Captain obvious
    Hastings, MI
    Has anyone thought about the kort prop nozzles?
  7. thegeek
    Kort props are OK but you can't use the nozzel in IRCWCC.
  8. Captain obvious
    Hastings, MI
    What prop size do I need for a NC?
  9. Bob
    On my NC I use 1.7 korts. They are as close to 1.75" as they have. If you are getting the soldered props 1.75". It's pretty standard for any ship over 25lbs to go 1.75".
