Looking For Props
Discussion in 'Buy, Sell and Trade' started by Nibbles1, Oct 20, 2019.
  1. Nibbles1
    Nibbles1 Well-Known Member
    Orinda, CA
    Can you tell the pitch?
  2. Julian Barbera
    Julian Barbera Active Member
    SF Bay
    You can bend metal props into the correct pitch. Those do look like 1-1/2" 4 blade 40 pitch. Pick some of those up and we can adjust pitch for speed pond side.
  3. Nibbles1
    Orinda, CA
    They are 1-1/4”
  4. Julian Barbera
    SF Bay
    Cut a pice if paper, 1-1/2in, and hold it to where the props go. If it fits you can go with the 1-1/2, BC doesn’t sell 1-1/4” 4 blades.
  5. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    I like the bigger is better formula Hole shot is a must with ships . I prefer kort props from prop shop. Kort props actual have a tapered pitch the prop pitch ranges from something like 20 to 50 pitch giving you the best overall performance in my opinion And Prop shop has cast bronze props not soldered
  6. Nibbles1
    Orinda, CA
    I measured it with calipers, they are 1.23
  7. ZARUBA1987
    Tarkington Tx
    Roughly 1 1/4
  8. Nibbles1
    Orinda, CA
    Yeah 1-1/2 might work... However I don't want to speed, I am a law abiding citizen.
  9. ZARUBA1987
    Tarkington Tx
    Just because you have a bigger prop doesn’t necessarily mean you will be going faster. Hole shot is about making top speed in the shortest distance possible without violating rules
  10. ZARUBA1987
    Tarkington Tx
    Just to elaborate a bit my ESC on my Doria is set up for high torq at low speed AKA hole shot and normal torq at cruising speed 26sec
  11. Nibbles1
    Orinda, CA
    Wait I'm confused. Is that a fast gun thing? I'm a big gunner so... However if it doesn't affect speed that is helpful. Thanks.
    What is hole shot?
  12. ZARUBA1987
    Tarkington Tx
    Yes a fast gun thing. I did not realize your big gun that may have a little bit different rule set? hole shot is how fast a ship may make full speed in the shortest distance possible. Kinda like drag racing.
  13. ZARUBA1987
    Tarkington Tx
    I would guess the only way a bigger prop could ever cause a problems with excessive speed if your not able to use a ESC to drive your motors
  14. Nibbles1
    Orinda, CA
    In Big Gun we have to get very close to scale speed.
    I just remembered, Kitakami is a old ship from before ESC's. Uh oh.
  15. Julian Barbera
    SF Bay
    Does the Kit use a servo and switches for motor control?
    It really shouldn't affect anything speed-wise, as I said before, you can get away with grabbing the larger props and bending them.
  16. ZARUBA1987
    Tarkington Tx
    Ahh
    ah makes since your under full power forward and reverse. If your able I would install a Hobbywing 880 ESC it will support both motors and is programmable.
  17. Nibbles1
    Orinda, CA
    Yep it has a servo.
  18. Kotori87
    Careful, guys. a bigger prop isn't always better, especially on Big Gun ships. That cruiser (and most other Big Gun cruisers) are using direct-drive, low-powered motors. They don't have the torque to turn a 1.5" prop. All you'll manage is a lower speed and/or a higher amp draw.
    Nibbles, if you want a nice set of props, you can always 3d print some. It's an interesting exercise in Fusion 360 to design, but then you get a better set of props than the flat-bladed props that you used to have. Also invest in an ESC. it's worth it.
  19. Nibbles1
    Orinda, CA
    Okay thanks, will do. Is a 3D printed prop strong enough though?
  20. Julian Barbera
    SF Bay
    Jeff runs 3d printed props on his lil' transports. I'm not sure if it scales up but it won't hurt to find out!
