pump issue
Discussion in 'General' started by Evil Joker, Nov 13, 2010.
  1. Evil Joker
    Evil Joker Member
    i have a 280 mabuchi motor(pump) hooked up to a battle switch 10a relay
    and it cuts off and on but when i hook it up to a 550 mabuchi (pump) its all good
    can someone help (6volt)
    Have you tried running the 280-size pump straight from a battery to see if it's the motor? If the battle switch works fine on the bigger pump, that'd be my next thing to check.
  3. Evil Joker
    Evil Joker Member
    yes i tried straight from a battery on amd off the pump
    Load and noload
    maybe a torque thing
    thanks tug
  4. thegeek
    Bad brushes on the 280 motor or bad wire on the 280 motor?
    The 280 motor that came on a mini pump I got had squirrely-weak terminals to connect wires to, wound up replacing it.
  6. Evil Joker
    Evil Joker Member
    the 280 works fine on the battery. can it be pulling more than 10a.
    can a 280 pull more amps than a 550
    Not under similar conditions... if the 550 is running fine with the pump in the water, a 280 running with a pump in the water will be drawing less amps (at the same volts). Should draw WAAAY less.
    Is the problem with the motor cutting in and out, or with pump output? My micro pump had issues with the impeller not staying locked onto the motor shaft. Motor ran but impeller didn't.
  8. Evil Joker
    Evil Joker Member
    will get some new motors tomorrow
    and start over
    well see what i can find out
    thanks for the help
    now for some football and BBQ
  9. SnipeHunter
    Have you measured the current draw for each?
  10. Evil Joker
    Evil Joker Member
    i cant dont have the tools
  11. Evil Joker
    Evil Joker Member
  12. NickMyers
    somewhat destructive way to test current draw: grab a couple cheap blade fuses at various ratings and put them inline, keep stepping down until you blow one. hardly an ideal way to test things but would give you a rough estimate of the draw
  13. Evil Joker
    Evil Joker Member
    it was a bad motor (it was a new one)
    thanks all for the help
  14. Tugboat
    Glad to hear eet hass been verfixened!! Heil Fluegel!
  15. Markus.Andersen
    Markus.Andersen Member
    Denmark
    This might be slightly offtopic, but since the matter as resolved I hope You will forgive me. :whistling:
    You may not have the tools to measure current, but it is possible to make such a tool for a few dollars.
    Its called a current shunt and can be made from a piece of wire and a cheap voltage meter able to measure milivolts.
    try google for "cheap homemade current shunt"-
    www.rcgroups.com/forums/showthread.php
    best regards
    Markus
