QE - Frankenship
  1. irnuke
    ...for any of you not aware, Ming is the CD. Expect no mercy. Or donuts.
  2. Lou
    Yes, but as I am from the South, shall I bring moon-pies and pelt him with them? It's a sign of respect in the south, you know, same as putting holes in his ship with your fingers prior to battle. Respect, nothing but respect. :woot:
  3. thegeek
    I do have a tendency to consume mass quantities of Moon Pies and wash it down with Cheer Wine.
  4. irnuke
    Noted! Bring Moon Pies to NATS to bribe CD Got it!
  5. Iunnrais
    Iunnrais Active Member
    Texas
    which flavor Moon Pie with that RC Coca Cola :)
  6. Lou
    Work continues on with wiring clean up. I want the inside of the boat to look great, but still be easy to trouble shoot/repair at pond side. So I used the top screw of the blast shield to mount a plastic wire holder.
    Wire is still inside the boat, the blast shield is lexan and should protect (time will tell). Bottles are in and do not interfere with anything.
  7. Lou
    Large wire loom that feeds the Kips, everything comes out with a few screws.
    In this shot you can see the haymaker magazine tube, easy to refill.
  8. Lou
    Overall shot of the stern, still looks clean to me.
    Bow shot, the WTC has extra wire that will eventually be shortened after her first battle next weekend.
    After the battle and any subsequent changes, will work on interior colors and graphics. I will finally try my hand at powder coating. Does anyone know if I can remove the head of the C02 bottle and reinstall (safely), or am I better off taking it to a paintball store to remove and reinstall? Will be powder coating the bottles, that is why I need to remove them (oven is over 400 degrees)
  9. thegeek
    Don't mess with the bottles or the valves, if you do you might have to have them re-certified, and hydro tested.
    Tugboat likes this.
  10. irnuke
    Agree 100%. If you must have color-coded or matching bottles, buy a matched pair.
  11. thegeek
    Electrical tape comes in many colors
    Tugboat likes this.
  12. PrepmasterNick
    PrepmasterNick Active Member
    Lake Charles, LA
    Dr. Thunder FTW
  13. Lou
    Going to wrap the tanks with vinyl, that will solve the issue.
  14. Lou
    Ok, I will try something new, vinyl wrapping of the tanks. Did some reading and ordered the following colors to test.
    Blue carbon fiber
    High gloss black
    Edge sealer
    This will give me a look and not worry about affecting the tank or certification (can always be removed).
  15. thegeek
    Now I that looks really nice but I have to question why you would want to impede the heat transfer with a additional coating?
    Tugboat likes this.
  16. Lou
    I guess I don't understand, can you elaborate? My goal with this build is to make the inside of the ship as nice as possible, and having flat black tanks just doesn't cut it. Powder coating is out (need to remove neck and then will have to be re-tested), now *I guess* if I wrap the tank it will act as insulation and cause the guns to suck. Sooo, maybe just paint the tanks?
  17. absolutek
    It's not a big deal to take them to a paintball shop (if you have one nearby) and have them remove the valve for you and reinstall and test it afterwards (if necessary) for you.
  18. thegeek
    Are you fighting this ship or is it just going to sit on the shelf? The CO2 system on your ship does have the potential to do very serious harm if misused.
    Tank certification and the adherence to normal high pressure protocols is very important and is one of the reasons you have a CD at events.
    Putting it bluntly, if you show up to a event with a modified or altered CO2 system on the high pressure side you can expect one of the most stringent
    inspections possible, and your modified tank will fail a visual inspection.
  19. Lou
    Define modified? Painted? Covered? I am VERY transparent about my build, this is why I am on this site and share what I am doing.
    Please tell me now, if I take a rattle can of paint to a tank that I will fail a visual inspection.
  20. thegeek
    The numbers on the tank have to be visible and not modified. If you just spray the tanks and make them uniform that is probably OK, but you aren't making it work any better.
