QE - Frankenship
  1. Lou
    Not glued yet, but this already looks better than the Mark1 version
  2. Lou
    Third one for the haymaker. The weight will be offset by the bow cannon mounted on the port side.
  3. Lou
    New impeller from Strike. Time to clean up this old pump.
  4. Lou
    Making the base for the pump. As one of the issues is water rushing by the pump as the ship is going forward, I am going to try to block some of that by making the brace solid on the aft portion, time will tell if this helps or not.
    Used the fiberglass angle and cut a slot for the pump discharge tube, then installed two threaded inserts at the top. Removed the nuts on the pump housing in preparation for the hold down.
  5. Lou
    Back bracket in place, this will provide a friction fit. Notch is for the priming hole on the pump housing.
  6. Lou
    Pump in between the brackets, now we just need to hold it down.
  7. Lou
    Top plate installed. Screws are short, so it takes less than 10 seconds to remove. This also allows me to create another pump that I can swap out in a minute if there are any issues, plug and play. Later in the build this will all get cleaned up and painted, but for now this is the rough assembly.
    jadfer likes this.
  8. Lou
    Now the moment of truth, did I install anything that will get in the way of the guns. The stern guns will fit with no issues, and the haymaker will be to the bottom of the turret in the picture below. So, success! Next will be installing the guns, and to do that I will need to finish wrapping the turrets in termite armor to get the appropriate diameter. I will cast in the vents and other detail as well.
  9. Lou
    Color check, everything is loosely placed in the boat.
  10. Lou
    Getting there.
  11. Lou
    I would like to introduce you to the son of Frankenship, Yosemite Sam.
    Marking out the rib locations.
  12. Lou
    Outside is taped and ribs are drilled prior to cutting.
  13. Lou
    Water channeling is defined, spacer blocks used to support the outside edge of the fiberglass sheet.
  14. Tugboat
    Wow. What are you driving in February?
    Congrats to John!
  15. Lou
    Using tracing paper, created both sides from fiberglass board.
  16. Lou
    Using batteries to hold it down, or the foam will push it up.
  17. Lou
    Both sides done.
  18. Lou
    @Clark: North Hamption, same ship I am taking to the Brew
  19. CURT
    Where did you get the fiberglass board?
  20. Beaver
    I believe he gets it from McMaster. http://www.mcmaster.com/#standard-fiberglass-sheets/=qckng4
    QE is looking good, Lou!
    Beaver
