Quick non-powered prop question
Discussion in 'IRCWCC' started by darkapollo, Jan 17, 2022.
  1. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    Just a few quick questions on non-powered props.
    They can be actual props? IE with blades? Not just flat disks?
    Can they spin freely so long as they are not providing any thrust? (Like a pinwheel)
    The rules are only very specific about drag disks and their size and shape. It only says ‘non-powered props must not be larger than powered props’
    The reason I ask is because I noticed in testing on my particular build with various sizes of drag disks, a large trough of water was created causing severe cavitation and at full speed, actually sucking the stern under.
    So could someone clarify rule C-5? I would like to print out some additional props for the outboard shafts as non-powered and wanted to make sure I was within the rules.
    notSoGnarly likes this.
  2. Kevin P.
    The answer to each question is yes
  3. darkapollo
    Carlisle PA
    Thank you!!
