Radetzky (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Feb 29, 2020.
  1. Kevin P.
    More of a photo dump for now. Been chipping away on this one, looking forward to use during campaign. Also considering a printed version
    Strike hull picked up a few years ago
    EF8F8416-16D8-4AC1-8A11-FFE1C145599F.jpeg CB8499A1-2A59-4A1D-B436-04B14AAEF62F.jpeg E3520412-DC9D-4034-988E-5550784342FF.jpeg
    motor mounts. Going with 540’s to have margin
    also subdeck round 1
    standard traxxas mounts
    A3EAD54C-90E6-48C3-A3B3-AB8FD26EBAC9.jpeg CCB01D9A-5DFE-426A-A065-9FE3AEFBB30E.jpeg F846770B-4FA2-425E-84F2-668FE7B5E454.jpeg 26A30877-3F59-45B7-9818-60761BB50149.jpeg ECFD91F7-CAC8-48B8-A204-ADEC1772911D.jpeg 732B91B0-E3F3-46D2-995B-B111FC375231.jpeg 2910CEF5-34E9-466D-A7A2-B8AEED7A4E4C.jpeg
    waterchannel
    deck going in
    7EEADF25-F9AC-4B67-8B5C-FB9D9C00D20A.jpeg 9AAF4E26-44C9-4D55-AF3B-6E5DAA18EC17.jpeg 072874D9-9BD5-4E7D-8FE2-3AC0A6C1528B.jpeg 5865BC57-A46B-4105-BB88-62990B092ACD.jpeg 5D17B019-B488-4550-9C75-D6F7141290C1.jpeg
    Pump outlet
    rudders (printed)
  2. Kevin P.
    Drew up barbs and turrets this morning
    Turrets will need some post processing
    aft
    sidemount
    Designed in hinge mounts, looks like they will work
    hopefully getting back into this build next week
    Nate G, Beaver and rcaircraftnut like this.
  3. Kevin P.
    Glued the barbs on last night
    Got the ships rotated so she’ll be back in the build space
    getting close to starting to drop things in, should have most parts in stock
    rcaircraftnut, Litch42f and Beaver like this.
  4. Kevin P.
    Last section of water channel
    will be mount point for aft solenoids/expansion tanks
  5. Kevin P.
    Worked on this one a bit tonight, getting the gun mags bent to clear the pump/provide easy reload access
    Ill make the superstructure around the stack cover these up. Should be quick reload during campaign (no aft deck removal required)
    Dropped in elbow and tube for bow sidemount. That mag will be next, but 75rd-er so will need to get creative to get it to come out in a good spot
    She'll be borrowing the control box from Tromp (multi-C+ESC+Receiver in roughly 2x2x2 box, swappable between ships in about 5 minutes)
    Once the mags are set, things should drop in pretty quickly. Looks like weight might be an issue, balance with all the principle components was great, but I'll have to pay attention to it as I wrap up the build
  6. Kevin P.
    Gun mount work. s curve time get the 75rd mag in
    all through deck for quick reload
    rcaircraftnut likes this.
  7. Kevin P.
    Deck epoxy finished and internal armor
    Checking weight with note parts in
    control box from tromp with evil test switches, reliability is doomed!
    Need to print solenoid holder for under deck
    stern
    Aft solenoid with accumulator and check valve, just fits
    aft gun mounts
    Should be able to start putting things in for real soon. She’s 11 lbs so still looking tight, will wait on battery mount until rest is done to see if I need to downsize
  8. Kevin P.
    Printed solenoid holder
    to align with bottom of T
    also made aft barrel holder
    Next steps will be co2 hoses and a couple wire leads, then ready to bench test I think
    Nate G and rcaircraftnut like this.
  9. Kevin P.
    Got co2 hoses in and her sheeted on Saturday
    Bondo-Ed up turrets
    layer of cloth on outside
    Boatmeister and rcaircraftnut like this.
  10. Kevin P.
    Took a few hours today to draw up the superstructure
    Got the secondaries printed
    an easy scale down from the main turrets
    planning to hold them with a through deck screw, easy to replace if damaged. Weight if tight so not planning to reenforce them for now
    should print up the rest tomorrow while working from home. Waiting on props from prop shop, need to test guns and paint
  11. Kevin P.
    SS printed today, vapor bath tomorrow
    I made the base of the stacks larger to cover the mag caps
  12. Kevin P.
    Painted, hopefully sea trials on Sunday
  13. Kevin P.
    Sea trails today, boat did well
    Didn’t finish mounting superstructure
    Pond became a moss casualty
    Bow is a little high. Hopefully finish up the last few things this week
    rcaircraftnut, Lou and Beaver like this.
  14. Kotori87
    Interesting trick with the series of draft lines to determine correct level. I like that.
  15. Kevin P.
    Yes, took me a bit to realize I could put draft markers on before putting it in the water
    Tested out guns, no issues, aim on sterns is very good
    Got SS attached
    Magnet hold down
    Renodemona and Beaver like this.
  16. Nate G
    Nate G Well-Known Member
    Bradford, PA
    So, have you purchased a van yet to transport your fleet???
  17. Nate G
    Bradford, PA
    kidding aside, I got a chance to look through your build details.
    Well Done sir!
    use of 3D for mounts and topside structures is excellent.
  18. Kevin P.
    Thanks nate, I picked up a CRV several months ago so capacity has increased. Planning on 7 boats for nats, so I’ll probably have to go vertical with some of them. Might make a small platform to hold the convoys
