RESIDEING
Discussion in 'Construction' started by Powder Monkey, Jul 1, 2008.
  1. Powder Monkey
    After the shake down and many a sorties she is in need of a new dress before the big dance at NATS. How are you all removing the old Balsa? I used the weld wood contact cement to sheet. Okay what are your secrets? [:D]
    thanks guys.
  2. ProfessorChaos
    ProfessorChaos Active Member
    Centerton, AR
    Chisel and lacquer thinner for final residue removal.
    Sharp blades and extra fingernail replacements.
  4. BoomerBoy17
    I might put out that guitar picks may work well. they are easy to handle, sturty(with the right brand) and can usually get into small areas. If you do try it monk, tell me how it goes.
  5. Kotori87
    I use a hammer for the windows, then a sharp chisel and hobby knives to clean off the glue and balsa from ribs, etc. The hammer part is particularly fun :D
  6. Powder Monkey
    Okay I guess it is Hammer Time (you guys who grew up in the 80 just started humming it didn’t you [:D] )
  7. BoomerBoy17
    I was born in the 90s and i know where thats from. But good luck Monk, you can do it!
  8. JohnmCA72
    JohnmCA72 Member
    Utility knife to get the bigger chunks off. Then I use a belt sander, mostly. Also a Dremel with 1/2" sanding drum for some areas that the belt sander can't quite get.
    JM
  9. Ragresen
    Ragresen Member
    I have heard that having the ship sit in the water for a few ours makes it easier to remove. Something about moisture that does soak into the balsa makes it simpler to remove it all. I am going to try this when I resheet the Des Moines before placeing her on display. She is getting Raided for parts to make the Kron Prinz active.
  10. BoomerBoy17
    yea monk, nothing like power tools to make everything easier. i like the idea of soaking it too, the water seeps in, making the wood more flexible, then the power tools, take care of it.
  11. EricMA
    EricMA Member
    Hey Monk there is an easier solution to this. Just don't get hit> :p
  12. BoomerBoy17
    Eric, thats what i told him to do in his recovery topic there. That is the best solution ever, but i dont think he has it in him.
  13. JohnmCA72
    JohnmCA72 Member
    Wood isn't the issue; that comes off easy enough hard or soft. What needs to be chipped, chiseled, ground, etc. is the glue.
    JM
  14. DarrenScott
    That's why I glue my balsa on with contact adhesive. Scrape off the old busted balsa, gently scrub the hull down with turps on a rag (using gloves) and voila! no glue.
  15. Powder Monkey
    Hey now Eric easier said than done once you leve the safty of the bench DOUH!!! but thanks for the advice [;)]
  16. BoomerBoy17
    Monk, i dont care who you are, or what kind of divine entity is looking over you, your gonna take hits anyway.
  17. JohnmCA72
    JohnmCA72 Member
    I'm going to have to give that a try. I've been using CA, which leaves a hard crust that has to be ground off. The basic technique is to lay beads of thick CA on the ribs, spray the sheet with kicker, & slap it on. With contact cement, I reckon you'd have to lay a bead on the ribs, place the balsa to get some cement onto it, wait, then apply for keeps, right?
    Turpentine dissolves cured contact cement, then?
    JM
  18. Powder Monkey
  19. ProfessorChaos
    Centerton, AR
    Even easier that that.
    Thin the contact cement 50%
    Cut a piece of balsa to fit
    paint the hull with the thinned glue and paint the entire piece of balsa too. (We tested, this DOES NOT MAKE IT SELF SEALING)
    Let both dry for a few minutes.
    Carefully,since you only get one chance, apply the wood to the hull.
  20. BoomerBoy17
    thats an interesting idea.
