Resin question
Discussion in 'Construction' started by Powder Monkey, Apr 1, 2008.
  1. Powder Monkey
    I would let you know if I had any fiberglass left my local shop ran out and promised it to me today got there and he said tomorrow I like to support the local guy if I can however I could have had it a lot faster on line and not dealt with the oh well attitude like he was doing me a favor what is this world coming too no one cares about service and integrity any more [:(!]
  2. EricMA
    EricMA Member
    what did you do go to Home depot??? :p
  3. Powder Monkey
    Probably had better luck there at least they ask you how you are doing before sucking your Wallet dry [;)]
    Napa stores usually carry fiberglass in $6 bags...
  5. Powder Monkey
    what weight?
    Pretty heavy, I don't remember off the top of my head, but it was heavier than the "heavy" that Hobbytown was selling.
  7. EricMA
    EricMA Member
    Hey Powser where locally can you get CA glue and accenlerator? The only place I know of near me is Hyannis and that is 45 mins away. Hobby stores are getting scarce around here.
  8. Powder Monkey
    THER IS ONE 10 MIN FROM MY HOUSE
    He sells the big bottle to[;)]
  9. Powder Monkey
    The true test just glassed my hull hope it is dry for the build session tomorrow [:0] LOL
  10. EricMA
    EricMA Member
    Hope you have a tank big enough for me to float my hull so I can find the water mark. It won't fit in my tub. going to have to buy a kiddie pool. I will need to pick up some ca glue went I get to your house.
  11. Powder Monkey
    I have a 27 by 15 pool will that work? just watch out for the icebergs [;)]
  12. Bryan
    Bryan Member
    The main difference between you "Bondo" and
    your "West System" is that Bondo is a polyester
    resin and the West System is an epoxy resin.
    Polyester resins are much cheaper to buy than
    epoxy resins. Polyester resins use a few drops
    of hardener per cup of resin, while epoxy resins
    are typically more of a larger ratio mix.
    (by the way they do not play well together)
    That is why they "SMELL" different. A longer
    working time will give you a smoother finish.
    If bulking up, use Cut strand Mat, not woven cloth.
    Woven cloth cannot be layered over woven cloth
    it is not good, if you need to layer either
    use just cut strand mat or alternate cut strand
    mat with woven cloth. If you use Resin WITHOUT
    "air-Dry" or "wax" it is easier to add layers afterward
    even if it dried, if you use resin with those
    ingredients you will have to clean and sand the parts
    to try and get a good chemical bond between the layers.
    Resins when mixed with hardener will"Cook-OFF"
    if left in a cup or pail as they are "Mass Sensitive"
    and the larger the "Lump" of resin/hardener you mix up
    the faster it will go as it generates its own heat.
    To slow this down after mixing well in your cup
    pour it into a disposable paint roller tray or other
    dish that is not as deep and spreads the resin/hardener
    mix out more, or better yet pour it over your mat in the
    mold and spread it out. for small batches always use weight
    to mix or graduated measuring devices.
    Both of these have a temperature range where they will
    not set up and or will set up really slowly, humidity and
    barometric pressure will also affect drying times.
    Basically they like a nice sunny, dry day, in the mid 70's.
    Hope that helps a little at least. I am no expert
    but iam learning as I go.....(a little at least)
  13. frank falango
    frank falango Member
    sebring florida
    I use poloester resin from wall mart cheap and works great.
  14. mike5334
    thegeek and ish311 like this.
  15. ish311
    ish311 Active Member
    North Central Florida
    now that is handy looking mike. when i run out i will replace my west with that.
  16. Maxspin
    Maxspin -->> C T D <<--
    Yelm, Washington
    Looks like good stuff
  17. pigeonfarmboy
    Champaign, IL
    I'm game to try it. You just saved me $175!
    Looks like cstsales is closed? Glad I didn't place that West System order yesterday....
    Haven't seen my instructions yet, during construction are you guys waterproofing all wood structure by coating with the resin?
  18. dietzer
    dietzer Admiral (Supporter)
    CST is still open. Their website is still up and running.
  19. pigeonfarmboy
    Champaign, IL
    Ah must have just been down this morning.
