Rudder controll question
Discussion in 'Propulsion' started by wfirebaugh, Oct 16, 2016.
  1. wfirebaugh
    wfirebaugh Well-Known Member
    El Paso Texas, USA
    I have a Rudder question what is the most degree a rudder can turn to port/starberd, is there a point where the rudder stops working or to less affect 90 degrees with a propeller jeting water at it?
  2. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    Depends upon what you want. I have seen boats that close off (twin rudders) to the point that the thrust bouncing off of the blockage make the boat go in reverse.
  3. wfirebaugh
    El Paso Texas, USA
    So there is no real rules to this subjest, or to do's and dont's or rulrs of thumb?
  4. SnipeHunter
    No rules on max rudder movement. I wouldn't make a single rudder boat turn the rudder past 90 deg, but depending on your setup that can work on dual rudder boats like warspiteIRC mentioned.
    I'd suggest setting it up to get as much rotation out of your rudder as you can and then fine tune how much you actually want with the endpoint adjustments on your radio.
  5. wfirebaugh
    El Paso Texas, USA
    thank you, it was just a thought that hit me that I had not thought of before and was wondering.
