Rudder stuffing tube size
Discussion in 'Propulsion' started by ZARUBA1987, Dec 24, 2018.
  1. ZARUBA1987
    ZARUBA1987 Well-Known Member
    Tarkington Tx
    This is a simple question. My rudder shaft is 1/8. What size tubing is used for the stuffing tube?
  2. Kevin P.
    The diameters go in 1/32 increments, so you want 5/32
  3. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    I like going up a couple sizes (usually 1/4” or so) then sleeveing down the end by brazing in successively smaller tubing sizes. Then I fill it with lithium grease.
  4. warspiteIRC
    warspiteIRC RIP
    Annapolis, MD
    Normally the top of the rudder post is well above sea level and does not require packing like the shaft tubes. and there is very little friction between to successive sises of brass rod. So I just go with the next size of tubing.
  5. ZARUBA1987
    Tarkington Tx
    Thanks. 5/32 it is. I’m just going to order a few feet maybe for future builds
  6. Sinkazuki
    Sinkazuki Active Member
    Colorado
    Zaruba, are we meeting yu at brou?
    Randy
  7. ZARUBA1987
    Tarkington Tx
    To be honest IDK. The Doria still needs a few things and I still need to assemble the Duca kit currently at teds for my secondary ship not nessary of course. I really lost some drive building and not actually battling. Houston still does not have a organized group. Ted constantly trying to change that. I look forward bomber Feild In January to do some practice runs hopefully iron out some bugs in the Doria.
    Then I will see about the brouhaha
  8. buttsakauf
    Garland, TX
    Very true. I also like the rigidity of a larger diameter tube as it relates to accidental drops, adhering to the hull (fiberglass hulls that is), and gear mesh for geared rudder setups.
