Video Saranac - Kentish Knoch
Discussion in 'Photos & Videos' started by kgaigalas, Nov 4, 2017.
  1. kgaigalas
    kgaigalas Well-Known Member
    Grand Rapids, Michigan
    WillCover and Panzer like this.
  2. Beaver
    I do believe Will has the fastest trigger finger in the whole hobby! :woot:
    kgaigalas likes this.
  3. WillCover
    WillCover -->> C T D <<--
    Harrison, Michigan
    whats a little spurting between friends!....
  4. kgaigalas
    If that's what you do to friends - -:eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek::eek:
  5. NASAAN101
    :D:D:D O, i could say somethink. But it would get my butt thown in the pond. :D:D:D
  6. kgaigalas
    Bring a boat and join the fun.:laugh::laugh:
  7. Kevin P.
    And by Derf, you mean Baden.
    Sounds like you forgot to tweak :)
  8. kgaigalas
    Kevin,
    It's a pain having a guy around that notices everything:):):) :):):bang:
    I started narrating incorrectly so I was stuck.
    My ship does need a winter over-haul (triples):(:(
    Kas
  9. djranier
    Mike Mangus has a recorded 11 shots in 1 sec, tested by Chris K. Everyone else was 1/2 the speed on average.
  10. kgaigalas
    He is GOOD!! :woot::woot:
  11. SteveT44
    Must have been a light tweek.
  12. djranier
    Nope, he always fires like that, and his guns hit hard. Are you saying you can fire 11 times with a light tweek also?
  13. thegeek
    only a switch to a PC and input/output software. I was there and was humbled at the speed of his finger.
  14. SteveT44
    I have no idea, never thought about it.
  15. Beaver
    If I had a setup that could achieve 11 shots a second I think I could shoot that fast or even faster. :)
  16. djranier
    Maybe you can. We had a youngster in Statesboro, that was unbelievably fast, never timed him, but it looked like he would give Mike a run for his money, but then Mike is over 40, and can still fire that fast.
  17. SnipeHunter
    The good paintballers can fire in the 10-15 balls/sec range (probably higher in quick bursts) in semi auto without ramping or any of that jazz. I suspect that you put in some time/effort you could get our cannons to do the same.
    I'm of the opinion that most people should worry about accuracy well before they worry about rate of fire.
    NickMyers, Beaver and SteveT44 like this.
  18. NASAAN101
    I always tho both were inportant...
    Nikko
  19. NickMyers
    You can't miss fast enough to win
    SteveT44 likes this.
  20. kgaigalas
    GLAS is working to get FASTER :bang::bang::bang:
