Scale armor idea
Discussion in 'Construction' started by Nathan Carpenter, Feb 19, 2015.
  1. Nathan Carpenter
    Nathan Carpenter Member
    Oklahoma
    First off i'm new to the forums and to the hobby. I see that the common practice for the hobby is either fiberglass hulls with balsa windows or thin balsa hulls. I'm thinking about experimenting with taking some armstrong industrial vinyl floor tile and heating it up with a heat gun and running it through a pasta roller to thin it down to the scaled thickness. I realize that this might make this build not qualify to participate in any battle groups. But if I'm not mistaken they perform a drop test and if it is penetrated would it really matter ? I think making the belts this way would be more realistic. What's your thoughts guys and gals ?
  2. Lou
    How would you patch the holes from combat? And after patching, would it pass the test? Don't forget the ships sit in the hot sun for a while, would this cause the vinyl to change shape?
  3. Nathan Carpenter
    Oklahoma
    I'm not sure that would be a problem because I would skin the hull in that area with the thinnest balsa wood I can get at hobby lobby the glue the belt to that. Then of course the paint will protect it to a degree from exessive heat I think that will be enough to prevent worpage.
  4. SteveT44
    Not sure what problem your trying to solve? As far as realism, the "armor" is nothing but. Unlike the real world we want to allow penetrations and the current balsa setup does that very well.
  5. jch72
    jch72 Active Member
    If you actually own a pasta roller you should build Italian.
  6. Nathan Carpenter
    Oklahoma
    It's not really an issue I was just wanting to try something different as an experiment. And I just think that it would simulate a ships armor belt with a little more realisim.
    The current rules allowing stringers do that pretty well. Best advice is to build a ship that is acceptable under whatever club rules you'll be playing under, battle it for a year, and then think about changes.
    GregMcFadden likes this.
  8. Nathan Carpenter
    Oklahoma
    I think I will build a test hull with the armor layout and build my first build to the club rules and then blast the test hull and see how well it does. One of the pasta rollers at walmart can go as thin as 0.05 the ship i'm planning to build is the dunkerque which has a belt that is 8.9 inches thick so I divided that by 144 and got a thickness of 0.061 which should be able to be made.
    I'm also in oklahoma and as far as I know there isn't any battle groups close by.
  9. NickMyers
    I'm struggling to understand what the objective would be here?
  10. Nathan Carpenter
    Oklahoma
    The objective is the vinyl composition can be used in place of balsa wood on a large portion of the hull and is significantly cheaper also and you wouldn't need to use as much sealers and polyurethane. And is still able to be penetrated easily
  11. SnipeHunter
    Good luck, please post some pictures and results of the process.
    You may find that replicating the behavior of good quality balsa when shot to be tricky (poor quality balsa on the other hand is very easy to replicate, but who wants that), I think there is some interest in a high performance and easily repeatable material for hull skins.
    Edit: While a high performance and repeatable sheeting material would be nice, dont think it is going to be meaningfully cheaper than balsa. The cost of balsa to sheet a ship is in the noise compared to the cost of the ship and the cost to attend events. (Travel,Hotels,Meals,etc)
  12. SteveT44
    I would think something like Depron foam would be a better choice than vinyls.
  13. Nathan Carpenter
    Oklahoma
    Well its just an idea at this point I plan on performing a few ballistics tests on the vinyl first if I build a ship that has a 12 inch belt in 1/96 scale the 1/8 thickness would be spot on.
  14. SteveT44
    A bb will not go through 1/8" vinyl.
  15. Nathan Carpenter
    Oklahoma
    Bb's might have a difficult time passing through it. But the bb's would cause damage to the belt allowing a follow on round to pass through it. Not unlike what would happen to an actual armor belt if it struck by a smaller caliber she'll. But I though the larger battleships mount guns larger then a common bb in which case they should be able to pass through it. Just like the larger battleship shells that's why I think that a composition vinyl belt would add realism to an extent. :)
  16. Nathan Carpenter
    Oklahoma
    And the composition vinyl would actually break and chip like this yamato turret face
  17. Lou
    Nathan, do your own thing and best of luck. Now that you have your goal, write up how you are going to test if you really want to get meaningful feedback from this crowd. Okie is fun, went to high school in Stillwater back in the day (and that was a long time ago).
  18. NickMyers
    It'd be interesting if it works - do try it and report back
  19. Tugboat
    I would do testing before building a ship :) Easier to control external factors if it's vinyl on a square window, more consistent results.
  20. Nathan Carpenter
    Oklahoma
    I'm going to build a sectional model of a hull and then conduct some tests at some point I need to purchase a few guns that's used in rc warship competitions that way I will be using the actual guns to ensure that I have accurate results.
