Sheeting/silkspanning!
Discussion in 'Construction' started by Beaver, Jun 10, 2014.
  1. Astrosaint
    Astrosaint Active Member
    Astatula, Florida, USA
    I have had success with Dollar Tree plain white gift bag style tissue paper.
    MMJR
  2. Maxspin
    Maxspin -->> C T D <<--
    Yelm, Washington
    Kimtech wipes.
    Found a box of these at work!!!
    This stuff looks very promising. :)
    http://www.amazon.com/s/?ie=UTF8&keywords=kimtech+wipes&tag=googhydr-20&index=aps&hvadid=28612466607&hvpos=1t2&hvexid=&hvnetw=g&hvrand=4464878387232809936&hvpone=&hvptwo=&hvqmt=e&hvdev=c&ref=pd_sl_j948vtcdw_e
    Keith
  3. SnipeHunter
    Yup those Kimwipes work pretty well, I've been patching with them all year long. No issues so far.
  4. Maxspin
    Yelm, Washington
    And here I thought I had an original thought. :p
    I will use the Kimwipes when I sheet my Liberty ship.
    Keith
    No issues with your tissues? :laugh:
  6. DarrenScott
    Its been pointed out to me that the paper teabags are made from is almost identical to medium silkspan.
    Surely there is a bulk supplier for that stuff somewhere?
  7. KeriMorgret
    Seattle, Washington
    Stephen has been looking into some of these alternative sources. I'm not sure the current status right now, but know he has been making inquiries. I'll ask him to add a couple of comments to this thread when he has a chance.
  8. smorgret
    smorgret Vendor
    Hell Guys,
    There are some versions of tea bag material that are very similar to silkspan. I have a couple of samples of the stuff, and all indications are that it works well. I can get it in various widths, some of which would be quite good for us (including long rolls a little over 6 inches wide). The really fun part is that the stuff is only available in serious bulk, as in I would need to purchase several thousand dollars worth of the material in order to get any at all. I've checked a lot of sources, and I have a couple where I have been able to bring down the minimum quantities only a little. The fun part is that these suppliers are dealing with manufacturers that are using pallets AN HOUR. If I can get commitment from a bunch of people to get $50 packs of silkspan, then I can put in the order and get the process started. It would take about 3 months from starting the order until it arrives.
    Stephen Morgret
    Strike Models
    jerbat123 likes this.
  9. SnipeHunter
    Thanks for looking into that Stephen but there seem to be enough alternatives that spending thousands for a custom order may not really be worth it for you. Maybe it is worth contacting some tea companies and seeing about getting the ends of rolls from them. We used to do that with newspaper since they couldn't use the last 100 or whatever feet on a roll and that is more than plenty for anyone that isn't a newspaper.
  10. DarrenScott
    They wont send a "sample roll"?
  11. smorgret
    smorgret Vendor
    I already have a sample of two different types. The sample costs are reasonable, but the shipping costs are not. The ends of the rolls are also not viable for use. They make pretty good use of each master roll in the process of slitting to make the smaller rolls that go through the stuffing machines. They have to be efficient, as the quantities involved are significant.
    Stephen
  12. Maxspin
    Yelm, Washington
    So the real question is…..
    Is it close enough to silkspan that you could market it to the plane guys as well?
    Keith
  13. smorgret
    smorgret Vendor
    The problem is that I have not been able to find any significant market with the plane guys. Most of the plane guys have gone to other materials a long time ago. I have also not been able to find a distributor that was willing to carry it if I purchased the large lot.
    Stephen
  14. ish311
    ish311 Active Member
    North Central Florida
    plane guys like the heat-seal vinyl which i haven't tested or looked to see if anyone else has but it is fairly expensive.
  15. Astrosaint
    Greetings:
    Here is another silkspan issue--if silkspan is going away, what about the dope ? What other uses dope has besides silkspan adhesion ?
  16. absolutek
    Antique aircraft restoration.
  17. SnipeHunter
    Minwax clear lacquer, they sell it at home depot, works great.
  18. ish311
    new aircraft also use dope. but nitrate dope is going the way of the dodo. waterbased is just a heck of allot simpler to use. and not as explosive in the can.
  19. absolutek
    I realize there are a great many different chemicles used in cloth covered aircraft, some people just use the old nitrate/butyrate dope because it is "how it was done originally".
