Shimakaze build
Discussion in 'Warship Builds' started by ish311, Oct 12, 2014.
  1. ish311
    ish311 Active Member
    North Central Florida
    Well massive failure. esc i picked up for $20 is a failure... have to put it in neutral twice to get it to go to reverse. so i'm taking the ESC from my Kongo and putting it in the mostly done Shimakaze.
    proboat 40 amp sealed unit just have to replace the futaba ends with the traxxas ones for the battery i have.
    tore out the poppit and moved it and i have a very large deadspace that if i find the right pump i can fit it.... and a space for servo/relay.
    What $20 ESC were you using?
  3. ish311
    was a traxxas xl5. it wasn't $20 that is just what i got it for out of a guys car that he wrecked.
  4. NickMyers
    I tried one of those. Ripped it out for the same reason.
    Nobody ever listens when Tug says buy the cheap one from HK and love life. Ah, well.
  6. ish311
    well tug when i was buying an esc i had to get stuff localy or i wasn't certain i could get it. had no clue what state i was going to be in any given week Dec-this monday...
  7. NickMyers
    Was a few years back for me
    I replaced it with one of those proboats which i incidentally also dont like, but it serves well enough in a convoy.
  8. bugler
    bugler Member
    Pacific Ocean.....
    Sorry for the bizarre question...but how thick are your bulkhead ribs?
    1/4" ribs on his boat. He's allowed to have more than he does.
  10. ish311
    I can add 2 more actually but havn't put them back in.
  11. ish311
    what is wrong with the pro boats?
    and what ESC are you talking about tug.
  12. NickMyers
    50% reverse and ive had troubles with their startup sequence in the ship i'm using it in -they seem to be very picky about the neutral position.
  13. CURT
    Been using the ViperMarine 75 amp. I am sure the 40 amp will work well.
  14. NickMyers
    I like (and use) the Vipers (Mtroniks) but he has, and I also have and dislike, the ProBoat 40A
  15. ish311
    if i get back to what i was working on this week i should have the skin on by thursday. just need to replace the rudder when the max allowed scale one shows up.
    We had the proboat 40 I think in a couple of ships and didn't like them either. They are good for regular RC but the demands of Combat are too much for them. BTW I said I used the 75 amp that is incorrect I use the 40 amp. Works great.
  17. Cannonman
    Hermitage, Tn
    I have 2 Mtronics, and they wouldn't work for me..... I don't remember why.... I need to hook one back up and see what the issue was. I do remember I had looked into it on the internet at the time, and others had the same issue..... Kind of a bummer since I have two of them, and between the two there are probably 30 seconds worth of run time on them....
  18. ish311
    well after i broke my only waterproofed servo ( fell out of box and got stomped on) i just ordered some scotchcote and will probably need to go find another hightorque mini servo to replace the not so high torque on on the rudder arm now.
  19. Tugboat
    ARGH! WE DIDN'T HIT THEM WITH THE SCOTCHCOAT!
  20. ish311
    well replaced the rudder with max allowed size and..... it has no throw on the servo arm now so i'm going to have to replace the setup and it's looking like chain driven is my only option. i can use the nice standard plastic gears without moving anything else in the boat i just may have to cut a section of the keel stringer out and reinforce it on the sides to get the hight i need.
    also need more gears as i have to choose if i get the shima or the kongo done 100%(maybe minus some SS) for first battle in march.
