Shimakaze Cad Modeling
Discussion in 'Digital Design and Fabrication' started by GregMcFadden, Oct 14, 2022.
  1. JustinScott
    JustinScott Vendor
    You should make a video of your process. Many of us would benefit from it; even if it's "raw", "messy", and "all over the place".
  2. GregMcFadden
    30 minutes of looking at documentation.... 3 minutes of drawing, followed by looking at results re the docs....
  3. JustinScott
    JustinScott Vendor
    Ahh. Then a 3 minute video would be awesome!
  4. TorpCruiser
    TorpCruiser Active Member
    Everett, WA
    How is this not NSFW?! Lookin' grrreat!!!
  5. GregMcFadden
  6. GregMcFadden
    Little things that take up way too much time... see the circled parts in red. The plans are inconsistent, and other sources not a ton of help, finding original documentation. I plan to go with the geometry shown in teh second image...
    Xanthar, Lord Haw Haw and TorpCruiser like this.
  7. rcengr
    I think you may be working on details that your printer can't reproduce. But it's fun seeing your work.
    I battled my Shimakaze exclusively in 2022 and I had a blast with it. I started with the same set of plans, but I tend to deliberately simplify parts. I'm looking for that "looks good" at 5' away, rather than scale accuracy.
  8. GregMcFadden
    Did you add deapth to the hull? Scale she is really light. A lot of this is simply a excuse to model in a little more detail than I have traditionally done mainly because I don't really have a ship that I really want to build this winter so
  9. rcengr
    I added 9.5mm in depth to the hull. The displacement of the ship ready to fight is 3.0 lbs.
    I needed the extra depth for both displacement and for the components. My pump still didn't fit, so it penetrates the deck and hides under the superstructure.
  10. GregMcFadden
    What were you using for propulsion? I had an idea I may try out but I don't have a normal kit of motor-esc-etc combo to go to for ships below ~9lbs
  11. rcengr
    Propulsion is two 2830 1100Kv brushless motors. Props are 3/4" x 25. The battery is a 7.4V 2 cell 1500 mAh LiPo. I'm running at 85% throttle to make 20 seconds/100'. I change the battery every 2 sorties and generally put 500 - 600 mAh into the battery to recharge it.
    The rudder is controlled with an HS-82mg servo and ball chain drive.
    The gun is a muzzle loaded, 15 round spurt gun. The pump is a printed resin body and impeller with a 380 size motor. From top to bottom the electronics are two brushless ESCs, Rx, brushed pump ESC.
    From left to right the gun components are: fill indicator (on vertical wall), whisker valve and servo to fire gun, 2 cuin Clippard accumulator, QEV valve, 1/8" ID line to gun.
    Also, the grey you see along the pump channel is lead ballast. I think there is around 8 oz of total ballast.
    Boatmeister and TorpCruiser like this.
  12. TorpCruiser
    Everett, WA
    Is the “magazine” of the spurt gun, the section of copper tube between clear tube and threaded portion above deck?
    Whats a whisker valve?
    Fill indicator?
  13. rcengr
    The short piece of copper tube is the magazine. It has a piece of 3/8 brass soldered on one end for the 10-32 fitting, and a barrel thread on the other end.
    A whisker valve is a control valve that lets you bleed air from a circuit. It is small and takes very little pressure to activate, so a very small servo can be used.
    b549c70303dc35e43a47aadeedb877258860a68e-256.jpg https://www.clippard.com/part/MWV-1
    The indicator just tells you if there is pressure in the system. When pressurized, a small pin pops up. Clippard doesn't make that model anymore, but here's something similar.
    fabf73bbfe78f4d548e4f5024381e4fb2fd6c6f6-256.jpg https://www.clippard.com/part/IND-3-GN
    TorpCruiser likes this.
  14. TorpCruiser
    Everett, WA
    Ok. Thank you. So, the whisker value is piped to 2, 3-port manifolds: the 1st, 3-port mani is for the whisker valve itself and the indicator (correct?), the 2nd 3-port mani is fed from the 1st manifold (correct?)...where do the last 2 hoses connect? I'm not really understanding the whisker valve...how does it fire the cannon if there is only one hose to it??
  15. rcengr
    It all comes down to how the quick exhaust valve (QEV) works. The accumulator fills through the QEV. As long as the pressure of the input and the accumulator are the same, nothing happens. When you reduce the pressure in the input line (by opening the whisker valve) of the QEV, the exhaust valve of the QEV opens and empties the accumulator. Here's Clippard's explanation: https://www.clippard.com/cms/wiki/how-does-quick-exhaust-valve-work
    The check valve is required to keep pressure in the system when I disconnect the fill hose.
  16. Kotori87
    Do you have some sort of block-diagram-drawing program, or are you just that good at Paint? I am supremely jealous of your plumbing drawings.
  17. TorpCruiser
    Everett, WA
    Thanks for explanation. So, are all 15bbs expended in one burst or can it be reduced to 3-5bb bursts? Are you using CO2? Thx again.
  18. Kotori87
    It's all one burst. Once the QEV starts venting towards the cannon, the only way to reset it is to re-pressurize the system. Since it is supplied on shore via a quick disconnect, you effectively get one shot.
  19. TorpCruiser
    Everett, WA
    Oh ok. Thank you, better not miss, lol.
  20. rcengr
    Yes, just one shot. When you hit it's great, when you miss it's a wasted sortie. I have a lot of fun with the psychological threat, lining up and not taking the slot, just to see them .
    squirm.
    I drew the diagram in powerpoint. I like powerpoint because once you attach the lines to handles on the boxes, you can move the boxes around and the lines adjust automatically.
    Boatmeister likes this.
