Shinano rebuild (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., May 2, 2021.
  1. Kevin P.
    A quick rebuild on a Shinano
    Quite a beast, makes the Scharnhorst look pretty small
    A few before pictures. main things to do are replace drivetrain, make space for weights lower in hull, probably add a few pumps
    Step 1 was remove shafts
    Cleaned out aft foam to make room for motor mounts and more level shafts
    I found those missing allen keys
  2. Nibbles1
    Nibbles1 Well-Known Member
    Orinda, CA
    Woah a Shinano!
    Don't see that ship much.
  3. Kevin P.
    Not much build time recently, was able to print up a little gearbox structure to go along with the 700 series motor mount. A bit much for a convoy but I wanted to get the motor slightly out of the water, I also wanted to use mainly existing parts so the 700 series 12V motors fit the bill
    Added 5 degree wedge to go under bracket
    Simple gear cover to keep out bits of things
    Hopefully get the shafts in next weekend
    Evan Fowler, Nibbles1 and Beaver like this.
  4. Commodore
    Commodore Well-Known Member
    Sunny TX
    Nice looking gearbox. Hope you put some cooling coils on the motors.
  5. Nomercy
    Nomercy Well-Known Member
    Maryland
    There will be plenty of water in it to keep them cool....lol
  6. Kevin P.
    Squeezed some time in tonight to get first batch done for shafts
    Will handle the gearboxes in the next batch, will be easier with the shafts solid in place
  7. NASAAN101
    I tho in IRC She wasn't legal??
  8. kgaigalas
    kgaigalas Well-Known Member
    Grand Rapids, Michigan
    I have been spending some time on a rebuild also ;););):):)
  9. Kevin P.
    15 minutes a day gets boats built
    gearbox is drying. Didn’t use wedges, used clamps to set angle off the gearbox reference. Through hull screws and some glass over, hopefully it all works out
