SMS BADEN
Discussion in 'Warship Builds' started by GregMcFadden, Nov 28, 2009.
    I think you should leave it black. Nice and Menacing!
  2. GregMcFadden
    and in the sun here a good way to roast the internal electronics in the summer ;)
  3. KeriMorgret
    Seattle, Washington
    A good sink will take care of that extra heat.
  4. GregMcFadden
    Yep it will. As an aside, if this deck works out, it can be readily laser cut from either 1/8" ABS or 1/8" Wood, and fit together.
  5. Hovey
    Hovey Admiral (Supporter)
    Washington
    Wow, looking really nice there Greg. Now I really don't want to post build pictures of my Bayern as yours looks so nice.
  6. GregMcFadden
    just wait for the cannons, I just have to figure out one mount point and then figure out how to make one hard part....
  7. GregMcFadden
    Now as soon as I figure out how to zero the X axis, a new part will be born.... (block is within 0.0005 inches per inch of travel along surface of 45 degrees off horizontal)
  8. GregMcFadden
    Very spiffy. If those are firing cannons, is there a stop block to keep them from elevating above the horizon?
    But either way, you once again show that you are Rediculously Skilled(tm).
  10. Lou
    Very Nice!
  11. GregMcFadden
    the screw that holds the rod in only allows zero to -~20ish degrees of elevation control due to the shape of the slot
    and thanks
    -Greg
  12. NickMyers
    i absolutely cannot wait to see this all come together on the water next year, even if it is shooting me
  13. jadfer
    Greg, are these for big gun? If not where does the oring go?
  14. GregMcFadden
    They will feed BB and 3/16 (you use a different O-ring for each size). the O-ring is in the white part. Access to the screw that compresses the O-ring is behind the servo, so to access, you set the servo in the horizontal position, loosten screw, remove servo (removing linkage not necessary) and adjust screw for O-ring compression.
    I just hope to get enough of it done before march because after that, there will be no boat time for a while... and a new future captain.
  15. GregMcFadden
    From SMS BADEN
    From SMS BADEN
    From SMS BADEN
    From SMS BADEN
    From SMS BADEN
    One of the neat things about this cannon, is that it could be made from a laser cut top and bottom part, an appropriately sized aluminum tube, and a cast or injection molded plastic to make the internal geometry (not a load bearing cast plastic). But if you had an injection molding machine and the right plastic, you could make the whole thing as a molded part.... not quite done yet, but coming along. one more of this style needs to be made and one of the single cannon style (or this style with one port plugged, which is easy to do)
    Looks really really nice!
  17. Hovey
    Washington
    Are these supposed to fire bb's or miniture shells? They look REALLY nice!
  18. JustinScott
    JustinScott Vendor
    That is flippin incredible!
