SMS Derfflinger 3D Printed Project
Discussion in 'Warship Builds' started by darkapollo, Aug 13, 2021.
  1. Evan Fowler
    Evan Fowler Well-Known Member
    Muskegon, MI
    I'm game for that. I know a hand full of guys who like to tinker. And thats about all I did with the konig last time. Best just bring it and we'll see what can happen. Even if it just trolls about thats half the battle. Guns and boards are easily prepared. Trust me all anybody wants is to see your boat working and you having fun
    darkapollo likes this.
  2. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    The last (two) sections are on the printer. It is going to be TIGHT with the plastic I have. But I -should- have just enough on this roll to finish the hull.
    Yes, both rudders are there. That can be changed easily. The front one can’t turn very far anyway.
    All of the minor (and one major… thanks worn out nozzle…) warping has been filled.
    In 38 hours I should have a completed hull frame!
    Then… sanding smooth… epoxy and fiberglass..
    robert reynolds and Evan Fowler like this.
  3. Kotori87
    Looking very nice! Glad to see you included the bilge keels. I think those are an under-appreciated feature on ships. They don't have a huge effect on your maximum roll, but they very rapidly dampen any rolls you may experience. Make sure to reinforce them. My own bilge keels get shot regularly, and I've had to replace portions of them that got blown away by particularly powerful sidemounts.
    GregMcFadden and darkapollo like this.
  4. darkapollo
    Carlisle PA
    I was going to reenforce them with fiberglass.
  5. darkapollo
    Carlisle PA
    2 and a half rolls of gray PETG.
    Nearly 2 weeks of printing non-stop.
    Longest print was 60 hours.
    Shortest print was 12 hours.
    Seems joined with brass rods, super glue, and welded with a 3D pen.
    Things left to print:
    super structure
    Deck and cross supports
    Propellers
    Turrets
    Rudder servo mount
    Things left to fit out:
    Wiring
    Solenoids
    Plumbing
    Batteries
    Skinning
    Things left to finish:
    Sanding, epoxy and fiberglassing
    Painting
  6. Evan Fowler
    Muskegon, MI
    Noice, can't wait to get eyes on it looks great!!!
    Panzer likes this.
  7. darkapollo
    Carlisle PA
    Going to give these a spin in some ABS slurry to smooth out and build up some thickness. I printed them a bit thinner than normal. Because they are on ⅛” shafts I’m having a hell of a time finding 4 blade 1.5” props for that shaft size. I am thinking of threading for 10-24 and making some dog drives for 4mm shaft props.
    Boatmeister likes this.
  8. Panzer
    Hell, MI
    It looks fantastic!!! Something about a derffy Hull I like to see.
    Evan Fowler and darkapollo like this.
  9. darkapollo
    Carlisle PA
    Thank you! She is very German looking. Very much function over form which I think makes her a beautiful hull.
    Panzer likes this.
  10. Mad_Modeller
    Mad_Modeller Active Member
    Edmonton, Alberta Canada
    Looking good. Be careful about adding to many layers they look very close to the bottom of the hull from the last picture.
  11. darkapollo
    Carlisle PA
    Only one fiberglass layer to give the bottom some “bump and thump” resistance.
    I don’t even know if the epoxy will bond to the petg..
  12. Panzer
    Hell, MI
    Use the West Systems G-Flex epoxy. That should stick to petg
    darkapollo and Evan Fowler like this.
  13. darkapollo
    Carlisle PA
    I was looking at the West Systems 105/205 or Total Boat…
    I will have to look at the g/flex to see how it compares. The plan is to finish gluing and get it sanded this week.
    Anvil_x likes this.
  14. darkapollo
    Carlisle PA
    About to start printing the super structure. Going to hollow out the rear funnel and make that my float. Not set on fixture method yet, but going to shove a cork in there.
    I put the ESC and RX in a little cubby so I could mount the switch in an easily accessible space, plus keeps them out of the hull for easier access.
  15. Evan Fowler
    Muskegon, MI
    You guys and your fancy printers. Looks great solid plan
  16. darkapollo
    Carlisle PA
    Under $200 for an Ender3, no reason not to have one ;) UNLESS you know people with one...
    Im putting money aside for an Ender5-Pro so I can do bigger ships and bigger parts (and do an actively heated enclosure, not my passive enclosure) to do ABS better.
  17. darkapollo
    Carlisle PA
    Hull is sanded. PETG is a pain to glue together but man I love how it sands like pine wood.
    Rudder servo mount is printing. Plastic for the deck will be here tomorrow.
    If… if I can get some drive gears (was hoping to do a 2:1 but cannot find a matching pinion and spur gear in the same profile to make that happen…)
    I…. Could do initial sea trials… like this weekend.
    I was playing with sheets of 1/32 bass wood (for another project) and this hull is going to be so easy to sheet.
    I believe I saw someone mention she should be mid 20lbs to the water line?
  18. Evan Fowler
    Muskegon, MI
    That is awsome, hope all goes well. There is a ship list with dimensions. Speed and weight available from the site.
  19. darkapollo
    Carlisle PA
    Deck is coming along.
    ordered some drive gears. They will be here next week. Worked out rudder motion as well.
  20. Commodore
    Commodore Well-Known Member
    Sunny TX
    Color me intrigued. Personally, I would rather print/buy gears for the rudder, I haven't been happy with pulleys.
    Otherwise, she's looking pretty nifty. Do you take commissions??? (haha!)
    (I have too many botes as it is)
