SMS Derfflinger 3D Printed Project
Discussion in 'Warship Builds' started by darkapollo, Aug 13, 2021.
  1. darkapollo
    darkapollo Well-Known Member
    Carlisle PA
    I really need a second (working) printer... :-/
  2. darkapollo
    Carlisle PA
    Just need to wire it all up! 12:28 or 2.33:1 so I should be between 3 and 4.2k at the prop depending on how fast these motors spin.
    And… I need to print some new props… and other bits..
  3. Evan Fowler
    Evan Fowler Well-Known Member
    Muskegon, MI
    I wish I had your motivation . Awsome build!!!
  4. darkapollo
    Carlisle PA
    I gave myself a deadline to get it in the water by October. Even if shes just a boat puttering around between everyone else ripping out chunks of balsa.
    Evan Fowler likes this.
  5. darkapollo
    Carlisle PA
    Started doing a thing… Thanks Beaver for the tips!
  6. Commodore
    Commodore Well-Known Member
    Sunny TX
    Looks good - I presume you have plenty of silkspan. How did the adhesion to the PETG go?
  7. darkapollo
    Carlisle PA
    I tested on some scrap balsa and some failed prints. Once the contact cement cured, it wasnt coming off without a fight.
    It is interesting though because I can peel the excess contact cement off the PETG very easily.
    I did uncover a design flaw and will need to correct it. The balsa sheet is 3” wide. One of the windows is just a hair larger than the sheet. I will need to print a tiny backer piece to cover that gap.
  8. GregMcFadden
    Looking nice. Check your required depth for penetrable area below the waterline. Some ships require 4 inch balsa....
  9. darkapollo
    Carlisle PA
    From scale water line I did just about 1.125” (of the 1” allowable) The issue is in the bow where that 1.125” below would remove any semblance of structural support. Everywhere else I am over on 3” wide.
    Scale waterline shown. Cursor is on the window where it is just… JUST covering at 1.125” below but with nothing supporting the bottom of that frame.
  10. darkapollo
    Carlisle PA
    I drew the sheet so you can see exactly where the soft spot is. That corner is JUST too low.
  11. darkapollo
    Carlisle PA
    Sheeting is D O N E!!
    Need to silkspan the outside.. but she is all skined! I was so tempted to throw her in the Jacuzzi just to see her in the water but not yet
  12. Evan Fowler
    Muskegon, MI
    Good choice pool chemicals are bad for every thing.
  13. darkapollo
    Carlisle PA
    Jacuzzi tub
    No pool chemicals. Just a big ass soaking tub.
  14. Evan Fowler
    Muskegon, MI
  15. darkapollo
    Carlisle PA
    I hate fiberglassing. So. So. Very much.
    GFlex is awesome stuff and the 3/4oz cloth I picked up soaks it like a sponge.
    But
    Ugh
    Itchy. So. Very. Itchy. And sticky.
  16. darkapollo
    Carlisle PA
    No worries! The only thing my wife wanted when we were house hunting was a soaking tub and our master bathroom has a big jacuzzi (or whirlpool, but it is jacuzzi brand).
  17. Mad_Modeller
    Mad_Modeller Active Member
    Edmonton, Alberta Canada
    So are you going to wrap just the outer hull and cut the windows out or are you going to wrap the ribs completely and the inside of the hull as well. Interested in the steps.
  18. darkapollo
    Carlisle PA
    I just wrapped the bottom to prevent rock damage. The PETG is easily repairable so not TOO worried about inner damage.
  19. Mad_Modeller
    I just got the Graf Spee superstructure today, I'll try for a picture of it in a couple of days.
    darkapollo likes this.
  20. darkapollo
    Carlisle PA
    If there are issues, please let me know so I can fix them.
