SMS Gneisenau (IRCWCC)
Discussion in 'Warship Builds' started by absolutek, May 13, 2013.
  1. Lou
    You could set it up to charge in the boat and only remove if there is a major issue to address?
  2. jadfer
    15ah for a weekend? .. Depending on the pump motor.. it may be per battle and maybe per sortie. In the Baden I would recharge my 4 packs that I ran in parallel for about 2ah on average between sorties... I believe that means I used about 8ah per sortie.. so 16ah per battle with 2 titan pumps, and not running full stream. You would need at least one more set.. and in addition to charge as a pack you need the balance adapter and a computer charger. If you charge single.. then a the brick charger will work.
  3. absolutek
    It is a bit of a stretch, I believe last time I took this boat to a battle I was able to do five sorties on the 8ah lipo that was in it at the time. I do have a second set.
  4. absolutek
    Low profile rudder servo mount V2. This will allow me to have the servo right up close to the stern where a standard servo will not fit, using BC gears to turn the rudder.
    rcengr, dietzer and Xanthar like this.
  5. absolutek
    Main turrets. The one on the left I did in Fusion 360 and 3D printed. The one on the right is the cast version that comes from Battles Connection.
    I am thinking since the one I made is actually not as tall as the BC one, and the BC one can't fit a cannon in it, I may add a little bit of height to mine so it can at least cover (most of) the breach of a cannon. Maybe add a breach shaped cut out a well.
