SMS Panzerkreuzer Wahnsinnig (Armoured Cruiser Insanity)
Discussion in 'Steampunk Flotilla' started by irnuke, Aug 16, 2014.
  1. irnuke
    Progress!
    20150502_172530[1].jpg 20150502_172519[1].jpg 20150502_172511[1].jpg 20150502_172500[1].jpg
    As you can see, I have rounded off the bottom edge of the hull, tapered it slightly at both the bow & stern, and filled (most of) the gaps where the "batch cut" ribs didn't meet cleanly up to the slots in the hull pieces with bondo. Another layer of bondo & a thorough going-over with the sanding mouse, and she'll be ready for West Systems!
  2. Ironbeard
    Ironbeard Active Member
    Very nice, very clean....please keep up the step by step process.
  3. irnuke
    No pics to post up, but the bondo'd hull is getting to be nice & smooth. :)
    Motor mount will be built & mounted next weekend (550 can direct drive....can you get more basic?) :rolleyes:
    Once motor mount is in place hull will get thoroughly coated w/ West Systems. Rudder servo & motor install, some simple wiring & test mule (no upper works or guns) should be ready for temporary skin (duct tape) for some water testing during the Memorial Day events in Ga. :woot:
  4. Lou
    Take pic's at the event
  5. SteveT44
    We'll need to see some speed figures and your thoughts on maneuverability, stability, stopping, etc.
  6. irnuke
    I'll do that. My guess would be:
    Speed: Is this thing supposed to move?
    Maneuverability: Yeah, right
    Stability: Icebergs are very stable
    Stopping: See Speed
    Lou and NickMyers like this.
  7. irnuke
    Also will need to document how much ballast is required to get it to proper waterline.
  8. NickMyers
    How many cinderblocks do you estimate?
  9. irnuke
    2.5..... Or maybe I'll just park my Baden on top of it.
  10. irnuke
    Update: Final coat of Bondo is on and sanded. Glued in a brace for the the balsa where the lower hull tapers in to prop & waterline stringer does not (pic later after glue dries). It doesn't look like I'm going to have time to seal the boat today. I will try and knock it out before next weekend....
  11. irnuke
    Ok, discovered I still needed to do some woodworking prior to sealing boat. Doesn't look like it will get done before Statesboro. I will bring the boat along, maybe we can get it ready for the water at Tuggy's before the end of the weekend....
  12. SteveT44
    Issue with the plans or execution?
  13. irnuke
    Nothing so serious as to require execution. 9 lashes for the supervisor should be sufficient disciplinary action.
    I need to do some shaping on the water channel, resize the battery cutouts. Stuff like that.
  14. irnuke
    Got the subdeck glued on this AM. Lots o' sanding to do before it's sealed.
  15. irnuke
    Finally did a little more work. Started forming the overhanging portion of the bow (similar to Furst Bismark)...
    It's going to need a bunch more sanding to get the proper fit, but you get the general idea from pics...
  16. irnuke
    Not really happy w/ the way the bow is coming out. I may have to cut it all out & start over....
  17. irnuke
    Question for you woodbuilders....
    Paint, then seal w/ Westsystems, or seal, then paint?
  18. NickMyers
    Seal before paint for me
  19. absolutek
    If you paint it first, the epoxy won't soak into the wood, and thus it will not seal properly or at all.
  20. irnuke
    Rgr...thanks, guys.
