SODAK Update
Discussion in 'North Atlantic Battle Squadron' started by bb26, Feb 6, 2008.
  1. bb26
    The rudder issue is almosty fixed. I just need to get a longer servo orn and the issue be fixed.
  2. bb26
    And with picking up more large hose yesterday, I can now get my pneumatics.
  3. Chris Easterbrook
    Good to hear Paul, I hope you can iron out all of your problems soon.
  4. bb26
    It should be ironed out. I figure I have about 3 hrs of work to complete it. Not really a lot. Some things are tabs for the hatches. tidy up a few wires/hoses. make sure the rudder servo is not hitting the side.
  5. Chris Easterbrook
    What days are you off next week Paul? let me know maybe we could get together for a sail if all goes well.
  6. bb26
    Next week I am working monday to friday from 9 to 5:30. I am thinking I might try the grove for a test sail on sunday. I want to see the boat on the water and to check for leaks.
  7. Craig
    Craig Active Member
    Get her done.
  8. Chris Easterbrook
    We can see what happens, do you have any plans for next weekend?
  9. bb26
    Well I am still working on the rudder. I am now making a platform to change over the rudder servo and center it in the stern.
  10. bb26
    Well more rudder work today. I now have to get some collars from Maritime hobbies. One of the arms was loose and that is why I was not getting a lot of throw.
  11. bb26
    Well I changed over my rudder system. I am charging radio and battery so I should know tommorow how well it works.
  12. bb26
    Well the Sodak hit the water for her first sea trial. It was the good, the bad and the ugly.
    Good: rudder system works well, it does not bind when thrown hard over and with engines running.
    Good: Pump worked well. An 8-10 ft pump stream
    Good: weight was balanced and sitting on the waterline. All weight was in except bb's
    Bad: Engines. No speed at all. It would make the pundua look like a speed boat. I think the engines need to be replaced.
    Bad: I need a servo extender for rudder and throttle so I can move receiver up front.
    Ugly: Some twits in a dragon boat asked the name of the ship. When told the name was Alabama they thought it was a model representation of the boat in Crimson tide.
  13. CURT
    Well Captain..not too bad 3 out of 6. 50/50 least the rudder is resolved. Well buddy. Question. What motors are you using. Are you direct drive, or gears? Are you in parralle wiring or series? What size are your props? Are they turning in the right direction or is one engine going reverse and the other going forward or are they counterclock wise but turning in the same direction. Are the batteries charged full? You sure?? How much grease in the tubes. Do the props turn freely or is there a lot of binding??
    Crimnson tide eh? Well least they didn't call your ship the Titanic, Aircraft Carrier, or submarine.
    Curt
  14. bb26
    Well Curt the Batteries are fully charged. As to what size the motors are I honestly have no idea. When I move the props the shafts move easily as well as the gears. The motors were wired as +ve from one engine to the negative of the other and then wired into the throttle. Even with dry runs on the bench the engines did not sound that great. I had just assumed it was the gears as I am not not used to what it should sound. I will be doing a motor switch out and going with another set of engines I have. The engines were not wired any differently than how they were last year.
    Ok that leaves me with the question(S) Where did you purchase the motors?
    If it was at Princess than you may have high V motors with high or low rpm. Running them at 6v may not provide the power to turn them over quickly through the gears.
    Got a pic of these motors?
  16. bb26
    Actually there were in parts box. I suspect you are right that they are highv with low rpm. I may have put the wrong engines in as I had some motors from dreadnouth that were set for 12 v.
  17. bb26
    Well motor change over occured today. What a difference in motors. I will be taking it out thursday for a spin to see how it runs. It should run well. The engines were just purring along.
  18. Chris Easterbrook
    What was the problem Paul?
  19. bb26
    I think I installed a set of 12v motors rather than the 6v
  20. CURT
    Looking forward to hearing the report after trials Paul.
