SODAK Update
Discussion in 'North Atlantic Battle Squadron' started by bb26, Feb 6, 2008.
  1. bb26
    This boat has never fully been built. I had it under construction until I could not get the pneumatics to function. I had it running at CANNATS X. We thought the balsa was too hard until I discovered the balsa absorbed the bb's as I had not waterproofed it correctly. So I am stripping the balsa and will give it a proper build this time. It definitely won't be as detailed as Curt's work but I will be looking to make things as modular as possible. Also a new cannon kit from Battler's will help as well.
  2. Powder Monkey
    Do it well enough to not want the Bismarck [:D]
  3. rarena
    MUST BUILD.... I have the bumpersticker from the IRCWCC!
  4. Chris Easterbrook
    Is guns all you are ordring from BC Paul you might want to think about getting an ESC for her as she is way too fast.
    Well the ship was riding very light. It would slow considerable at full weight.
  6. ChuckR
    ChuckR Active Member
    I've had nothing but bad luck with ESC
    Chuck you need to research carefully with the ESCs. There were a lot of good threads about EScs.These forums are a good place to research before you LEAP into a new piece of unfamiliar equipment. Stick with the basics for now till you get a handle on it. Then go for the Esc later.
  8. bb26
    I am almost thinking sodak should be entirely gutted. Any thoughts Curt?
    Yes. Howz that for a thought?
    Actually Paul I took pics of the interior. Let me look at them tonight and I can advise much better. The sheeting is a no brainer. Remove that. More later
  11. bb26
    I am thinking that the shafts should be removed. all parts except the rudders removed and then start from scratch again. If you want I can get the good camera and take some detailed pictures of the ship.
  12. rarena
    I redid mine a bunch of times until I liked it.... oh yeah I still don't like it, I will be re-arranging some stuff this winter. Battling it really helps decide where things need to be. I found all my gun to solenoid wires keep getting tangled up in my forward magazines so I will be changing that.
  13. djranier
    Sounds like what I did when I was making my Kumano. I mounted the rudder stuffing tubes 5 different times before I was happy with it.
  14. Jay Jennings
    I have found a guy in NY who sells the Viper Marine ESCs for $57 a piece. Shipping to up here would be between 10-20 dollars depending how many are ordered. I intend to order some and have them for next season if anyone wants to combine orders.
  15. Chris Easterbrook
    I will keep that in mind Jay. When do you intend to order?
  16. Jay Jennings
    I'm not sure. I would like to have them asap but that probably won' t happen, need a new roof.
  17. Chris Easterbrook
    Ouch yeah the car needed some work and has left us a little short.
  18. rarena
    BB26, did the pictures help?
  19. bb26
    Actually they did. I took a look at how you set it up. It has given me more ideas on how I can get it set up.
  20. rarena
    Nice, I'm glad to hear that. I lay the gun magazines over all that and try to get the decks on. I will be doing the deck details over and will have a photospread to post. I also plan on going direct drive to get more prop speed and then drag disc it down. I want to get it turn a bit better. The changes never stop.
