SODAK Update
Discussion in 'North Atlantic Battle Squadron' started by bb26, Feb 6, 2008.
  1. bb26
    I will be waiting. No further work hs been done on the boat. Once motors are in then it will full tilt once again.
    They are on the way. Sent them out today.
  3. bb26
    Thanks Admiral. I have 1 installed. Once installed I can place the pump and then arrange how I can place in the batteries.
  4. Chris Easterbrook
    Good going Paul it seems like everything is starting to fall into place.
  5. bb26
    The only pieces being blown off is the balsa of the Axis fleet
  6. bb26
    10 - 2 Caps over B's
    I know it has nothing to do with the SODAK but still the Boston Bruins are losing.
  7. bb26
    I hope you like cold water Craig as the Bismark sinks to the bottom.
    Craigs Bismarck also has the ability to morph into a sea animal..yeah you should see it turn "Turtle" many times this season....Muuuhhhaahhhhhhh hack,cough, spit,,choke.
    BB26 that is a Captn with Ice water in his Veins...that's allright bring the barbecue.Were gonna have those German swine roasted.Should keep their blood boiling as they vent in frustration as each monster returns back to the deep from where they came from...poetic justice.
  10. bb26
    Some nice sauerbroten barbequed by some southern hospitality
  11. CURT
    I had to resend the stuff Paul. Bubble wrap didn't work and it would take too long. I got it repackaged and it will arrive Thursday according to CANADA POST. I sent you one motor mount with gears. The Gears are 13t. I don't have any more 12t.They were installed in Roma. Go with the gears and use smaller or less bladed props and install your drag props.
    Great I have a box just large enough to ship out the so called ADM of the Bismarck. Would you like to be sent by Parcel or crate Craig...hmmmm??
  13. Chris Easterbrook
    * shakes head, groans * man that was sad.
  14. bb26
    Anyways. The last of gears arrived today. It is now time to install engines and commence wiring.
    Go BAMA GO!!
  16. Chris Easterbrook
    Paul how's Bama coming along?
  17. bb26
    I haven't worked on it much this week. I am still installing the gear boxes. I have to pick up some balsa this week and maybe some tool dip. it is gets warm enough I might tool dip outside the servos. Or I will go over to my sister's basement and complete the tool dip there.
  18. Chris Easterbrook
    Well get the balsa at least so you can get her sheeted, then once you get her gear boxes in you can start to wire her up. Then it's only a step or two before you can start installing her guns.
  19. CURT
    Paul you are soooo close to finising that ship.
  20. bb26
    It is getting closer. Tommorow will be a run to Maritime Hobbies for some Balsa, silkspan and some dope. I am going to look for some dialectric grease so I can grease up the Spektrum receiver. Engines are wired but they just need to be installed. All systems will be labelled.
