Some Questions
Discussion in 'General' started by Nibbles1, Oct 12, 2019.
  1. Nibbles1
    Nibbles1 Well-Known Member
    Orinda, CA
    Two questions, for big gun especially. Should I put mesh in my ship? I know some people do it. Is it necessary?
    and what kind of string should I use for my recovery float?
  2. buttsakauf
    buttsakauf Well-Known Member
    Garland, TX
    Yes, shielding your internals is a wise choice. I would use para-cord or something similar/smaller for a recovery line.
  3. jstod
    Shielding is good to protect internalsas well as prevent through and throughs. Aka ball enters one side and exits the other side thus you have two holes in your ship
  4. Nibbles1
    Orinda, CA
    Makes sense.
    What kind of mesh do you recomend
  5. jstod
    I used pet screen on my Lützow which can be found at local hardware store. I’ve seen plexiglass (I think) used. basically anything that is lightweight but strong enough to stop 1/4” ball bearing at point blank range. The pet screen has some give to it so it catches the ball. It also allows water to flow through it so you don’t have to worry violating free flow of water rules.
    There is always more then one way to do something so look around at what the other guys are doing:)
  6. Z Boat
    Z Boat Well-Known Member
    Roseville California
    Here is pet screen from Home Depot. It is very easy to work with and there are many ways you can attach it. photo 4.JPG
    jstod likes this.
  7. Nibbles1
    Orinda, CA
    Okay last question (hopefully):
    how do you install it?
  8. BigGunJeff
    BigGunJeff Well-Known Member
    I like to just use hot glue. Others use fasteneners like screws
  9. jstod
    It depends on if you want to remove it often or only during refit. My Lützow came to me with plexiglass (I think?). It slid onto little holders attached to ribs. I moved to pet screen glued to Velcro. Kind of a pain to install correctly the first time but after the glue set I was able to easily take it off when needed.
  10. wdodge0912
    wdodge0912 Well-Known Member
    Doesn't matter
    My ship uses a bolt sticking out from the rib, and a coupler nut.
    My internal armor is fiberglass, and will eventually be replaced with shower pan liner.
  11. Anvil_x
  12. Nibbles1
    Orinda, CA
    How long does the recovery line need to be
  13. NickMyers
    how deep is your lake?
  14. Nibbles1
    Orinda, CA
  15. jstod
    If I remember correctly Joes pond is not deep at all from how he described it (I have not seen it in person). Ask him.
  16. BigGunJeff
    Around 8' at its deepest I would guess. It's full of sea monsters though...
    We spent a lot of time pulling water plants out, and they all came out with huge crawdads attached.
    Z Boat, jstod and Nibbles1 like this.
  17. Z Boat
    Make the line 10' and you will be fine besides the fishing pole has brought up ships from 30'.
    Nibbles1 likes this.
