South Dakota 1920 (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Jan 17, 2022.
  1. Kevin P.
    Which Navy Yard museum? The DC one still exists, I worked on the navy yard for a couple years.
    For hard area, I like to go conservative on rule compliance, especially for non pond-side adjustments. It should be fine to get shafts and rudder post mounted with the normal 1” below cut out
  2. Commodore
    Commodore Well-Known Member
    Sunny TX
    As you like, it's just that your marked area around the rudder seems a bit thin to me. Wouldn't want a ram to take that out or something. I have the same feeling about how some of the German battlecruisers end up looking in the bow, but such is the way of things, I guess.
  3. Kevin P.
    Windows cut out, thickness is good almost everywhere. I tried out a multi tool but quickly reverted to Dremel, I had a lot more control with the Dremel and didn’t want to risk the stingers
    A bit of repair where the glass pulled back
    Boatmeister likes this.
  4. Commodore
    Sunny TX
    Looking good, both of 'em!
  5. Kevin P.
    Finished up fiberglass defect repair, started drivetrain
    Boatmeister, Nomercy and Beaver like this.
  6. Nomercy
    Nomercy Well-Known Member
    Maryland
    Did the gel coat make any noticeable differance?
  7. Kevin P.
    It worked well on the cruiser but had some issues with the sodak, I did the whole layer at once, then tipped the boat on the side for the first side, the side that was in the air delaminated a bit. Moving forward I’ll either do multiple batches, or just skip it. I also was light of the catalyst, so everything took a while to set up, might go a little higher whenever it gets warm enough to lay another hull down
    I actually got some weekday boat work in today, motor mounts are drying
  8. Kevin P.
    Shafts in now, no need for struts
  9. Nomercy
    Maryland
    Looks good and flat
  10. Kevin P.
    Drag shafts and rudder servo mount are in
    Boatmeister and Beaver like this.
  11. Kevin P.
    Subdeck and deck rim cut today, hopefully install tomorrow
    Lou, Commodore, Beaver and 3 others like this.
  12. Kevin P.
    Deck rim epoxied in, the annual clamp inventory check. Also bonding the rudder halves together
    Panzer likes this.
  13. Kevin P.
    Since the last post I filled in along the deck rim, and added waterchannel today
    Deck rim cut down with pump outlet tubes
    Waterchannel
    I used dowels cut to length as depth gages (dark spot showing)
    Aft area, more will be built up in extreme stern, keeping it low for solenoid stacking
    main length
    Terry Keef, GregMcFadden and Beaver like this.
  14. Kevin P.
    Deck pieces cut out
    Reinforcement for aft deck
    rudders we’re also made a bit ago
  15. Kevin P.
    Deck magnets and deck pieces
    Barbs, turrets, and starting guns tomorrow
  16. Beaver
    Those deck hatches look almost identical. Sure you aren't building two of these?
  17. Commodore
    Sunny TX
    One for the triple stern guns, and one for the dual stern sidemount setup, no doubt. :p
  18. Kevin P.
    Maybe yes, maybe no haha
    Turrets and barbs draw up today, thanks to @bsgkid117 for the turret file
    planning for two magnets for mounts
    Justin Ragucci, Nomercy and bsgkid117 like this.
  19. bsgkid117
    Looking good @Kevin P.
    My own is progressing quite well. Hope to show it off on Saturday at the build session in MD.
    Justin Ragucci likes this.
  20. Kevin P.
    Deck rim finally sealed completely, barbs and turrets printed, barbs installed. This thing is built like a tank
    next will be cleaning up deck pieces a bit, gun construction, mock install for component placements. I’ll start superstructure at some point as well, maybe bilge keels
    diceman42, Panzer, Lou and 2 others like this.
