South Dakota 1920 (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Jan 17, 2022.
  1. Nomercy
    Nomercy Well-Known Member
    Maryland
    Justin Ragucci and Kevin P. like this.
  2. Kevin P.
    Guns and bilge keels
    Trying out the New drill press, took @bsgkid117 idea for printed holders which was way better and quicker than the normal clamping method
    normal and bar stock elbows
    Bilge keels glassed in
    more guns tomorrow hopefully
    WillCover, Lou and Beaver like this.
  3. bsgkid117
    Looking good Kevin.
    A small suggestion on your printed jig. If you add 90 degree wings at the top of the jig, they'll sit on the vice and it'll be very easy to plop the elbow in the jig, put the jig together, slide it into the vice and you'll know the elbow bore is parallel to the drill bit.
  4. Kevin P.
    That’s a good idea, I’ve always used the bottom of the vice so that’s what I used here as well
  5. Kevin P.
    Some gun progress for a few projects
    bilge keels cut down so the boat stops looking like a mid 2000’s VU
    more guns, small things on deck pieces, solenoid placements and mounts, printing superstructure this week
    bsgkid117 likes this.
  6. Kevin P.
    Reinforced the barbs, knocking the superstructure out. Gun work as well, and setting up the new lathe
    Boatmeister and bsgkid117 like this.
  7. Beaver
    Oh yeah?
  8. bsgkid117
    Making great progress. That rear SS is a monstrous box. No clue what the Navy was thinking with that one.
  9. SteveT44
    Looks like mainly crew berthing. The class was supposed to be faster which meant larger machinery spaces. Had to move the crew up I imagine.
    Justin Ragucci likes this.
  10. bsgkid117
    Not sure where you got those plans, the ones I have show a full-size Amazon Warehouse in those aft SS levels.
  11. Kevin P.
    Various updates
    Deck magnets
    assembling the distribution center
    Painted deck to make final assembly more efficient
    Starting gun assembly
    Aft solenoids and pump notional spacing
    The space will fill up fast. I've already run out of room .
  13. Terry Keef
    Terry Keef Member
    Conway, Arkansas
    You should market the holders for drilling guns. You could probably make a profit.
  14. Kevin P.
    Starting to make progress again
    Forward guns
    checking balance
    new pump screening idea to test out
    solenoids for bow sidemounts
    B62B50E8-2926-4AA6-9D00-A43A48F0961F.jpeg 8AE47CC1-F467-4F83-8D53-D42FEC3AB5E0.jpeg
  15. Kevin P.
    Half unit outlet
    forward pump
    bus bars
    through hull screws
    duct tape pre sheeting
    battery shield, polycarbonate
    sides on, mostly, trying dollar store tissue paper for silkspan. still need to clean them up and press everything down
  16. Terry Keef
    Terry Keef Member
    Conway, Arkansas
    Very nice. It's coming along nicely
  17. Nomercy
    Maryland
    Its Red. Its gonna die.....
    notSoGnarly likes this.
  18. Kevin P.
    Sodak will be making red boats great again
    Nomercy and ZARUBA1987 like this.
  19. Kevin P.
    Float test and barrel holders, the balance was awesome for first try, 34lbs 11oz, bit heavier thank planned
  20. JustinScott
    JustinScott Vendor
    Congrats!!!!
