South Dakota 1920 (IRCWCC)
Discussion in 'Warship Builds' started by Kevin P., Jan 17, 2022.
  1. Kevin P.
    Float spool, float alignment mounts, and painted. the alignment posts fit inside the distribution center
    simple spool
  2. JustinScott
    JustinScott Vendor
    Tell us more about that spool?
    it’s hard to see from the photo how strong it is.
  3. Kevin P.
    It’s a simple spool attached to underside of float, so strength isn’t a key factor, the spool is printed in two halves, with a 1/8” hole down the middle for a fiberglass or stainless rod, simple printed supports. Dimensions for this specific one are 1.125” dia for the spool and about 3” long, it holds 10ft of 3/32” cord easily. I have a 10-24 screw through the bottom of the hull as a lifting anchor
  4. JustinScott
    JustinScott Vendor
    Got it. That’s on the float.
    What do you have it anchored to on the hull?
  5. Kevin P.
    10-24 screw through the hull.
    First battle / sea trials in the books this past weekend in NJ
    several things to address, needs to go on a diet, need to cut down the rats nest, going up in motor speed from 900kv to 1100, some co2 system improvements
  6. bsgkid117
    Glad you could make it @Kevin P. Also glad that despite the weather you were able to get some valuable combat trials for South Dakota.
    Justin Ragucci likes this.
  7. Nomercy
    Nomercy Well-Known Member
    Maryland
    Guns worked good...lol
    diceman42 likes this.
  8. Kevin P.
    Some work before the Maryland battle this weekend. Shifted to larger gun hose, added a solenoid, plastic mags for weight considerations
    cage masts
    Just about ready
  9. diceman42
    diceman42 Member
    SoCal
    This is a really impressive build
  10. Kevin P.
    Updating this build with some more details
    I made two decks since this boat has the unique feature of having two aft triple turrets and enough units to fill them. It was a major design decision that I had to build the rest of the boat around, fitting 3 bottles and 6 aft solenoids and accumulation tanks. I’ll take some more internal pictures soon, but here are a few from testing
    Getting them to hit together was important, this was a shot while dialing the two groups in
    test on a few boats that need resheeting
    They need some more work to get them performing that well on the water, I ran them 1st sortie for two battles and both campaign
    a few shots from nats
    And a highlight video
    View: https://youtu.be/3cecqZE1dyE?si=vwh_IXgWN_73gJ4U
    Commodore, WillCover and Beaver like this.
  11. Commodore
    Commodore Well-Known Member
    Sunny TX
    Very nicely done! It appears that you had the same problem I had, of not realizing how close your stern guns were really hitting. I'm afraid that I dumped too many shots in the water Monday and Tuesday.
  12. Kevin P.
    Yes, the on board camera is enlightening, explains why our hit rates are so low
    some pictures of internals
    Bow section
    Tubing for mags from weight restrictions, space for pump
    Aft aimers, need to hold both ends of barrels to really get them to hit together, tips can adjust up and down
    About at the convergence point
    Working on guns a bit before the nj battle
    notSoGnarly and Lou like this.
