Spring Rumble in Ravenna 2008
Discussion in 'Washington Treaty Combat' started by froggyfrenchman, May 3, 2008.
  1. Gettysburg114th
    I understand your logic. Get those ribs together!!
  2. klibben
    klibben Member
    Unfortunately I wasn't there on Sunday, so I didn't even get to see Josh...
    Yeah, I've heard Mogami's rule the pond with Treaty...
  3. crzyhawk
    I wouldn't say they rule the pond. They're pretty awesome cruisers, but they have their weaknesses too. If a capital ship manages to get a hold of one it's pretty much over. Treaty is all about team work.
  4. klibben
    klibben Member
    well every ship has disadvantages - especially when a capital ship gets ahold of them!
  5. Gettysburg114th
    We count sinks and not points so it would be very hard for any cruiser to rule the pond. You can have a hole lot of fun but, it would be real hard to sink someone with a cruiser. Not out of the question but, it would be hard. That's why I am going with a ship with dual sidemounts. Now that I think of it, it has dual everything, dual pumps, dual sidemounts and dual bow guns.
  6. crzyhawk
    And easily twice the patching!
  7. Gettysburg114th
    Hey, why doesn't Bob get wet??
  8. the frog
    the frog Member
    The bulged heavy cruiser mogami is only 35 knots the light cruiser flat sided with 15 6inch guns can run 36.Mikey looked that up last year for lees mogami when it ran with us in treaty
  9. crzyhawk
    Thanks for correcting me on that. I've really only ever considered the light cruiser variant because it looks cooler in my opinion. I think the hulls that Ralph made are bulged, heavy cruiser hulls, so they'd only be able to do 35 knots. If the Mogami was built on one of those hulls, it would need to be slowed down a second to 25 seconds rather then 24.
  10. the frog
    the frog Member
    35 kts or 36kts it is still a killer.
  11. klibben
    klibben Member
    Sean Hert made a mold for the flat sides Mogami (which is what I have)
  12. the frog
    the frog Member
    Didnt I see 5 twin turrets on your ship saturday
  13. crzyhawk
    I'm pretty sure that the Kumano/Suzuya 8" cruisers have a different set of bulges compared to the Mogami and Mikuma. After the Tomozoru and 4th fleet incidents, construction on the Kumano and Suzuya were halted, and measures to increase their stability were built into the hull. A look at their hull lines show that the Kumano and Suzuya ended up with far less radical bulges then did the Mogami and Mikuma did because the changes were integrated with construction.
    So, as 8" cruisers they are allowed to have less bulgy sides.
  14. Gettysburg114th
    Mike, I thought I read that the Suzuya was the only ship in the class to be built with bulges?
  15. crzyhawk
    I'm pretty sure that's not correct. Suzuya was the first ship to be COMPLETED with bulges, but looking at their lines, they are much more integrated then those on the Mogami and Mikuma. That's because they were added during construction as opposed to failing their sea trials and having to go back into the yards for a rebuild like Mogami and Mikuma did. Mogami and Mikuma's bulges are a lot more radical because they were added after completion.
    I am positive that Kumano was the last to complete and incorporated all the same changes that were made to the Suzuya design.
  16. klibben
    klibben Member
    Actually, I believe that the Kumano was even more bulked up than Suzuya.. Suzuyas sea trials revealed her stern was still too weak and would warp during trials (due to using electrical welding to try and lighten her up) and therefore Kumano was even further reinforced.
  17. Gettysburg114th
    Thanks Mike, I knew that Suzuya was completed with bulges but never really read up on the Kumano. I know the hull I had from Canada was not bad as far as bulges. It would not be hard to skin.
  18. crzyhawk
    I'll look those two (Suzuya and Kumano) up specifically and see what I can find in my Japanese cruiser bible.
