Stands?
Discussion in 'Construction' started by Wolcott27645, Dec 19, 2014.
  1. Wolcott27645
    Wolcott27645 Member
    North Carolina
    What are people using to keep their ship up right while building it to keep it from tipping over?
  2. absolutek
    Personally I use a table, I have seen others build a cradle from two plywood uprights with hull shaped grooves fastened to a board or even PVC/abs pipe to form a cradle.
  3. Kotori87
    Designing a boat stand depends heavily on what you need it for. Stands range in purpose from preventing under-hanging props and rudders from banging on the table to protecting the ship during transport to being a complete travel kit with all necessary support gear/tools in one spot.
  4. NickMyers
    Something heavy on either side.
    I usually toss a block of wood under the aft end of my derf to keep the running gear off the bench, but otherwise its stable enough without a cradle.
    Nylon straps slung from uprights make a decent and adaptable cradle.
    If my ship doesn't have a big flat area on the bottom (or even quasi-flat), I get a flat board, and use super glue to attach wood blocks against the hull at front and rear to keep it from rolling while I work.
  6. Iunnrais
    Iunnrais Active Member
    Texas
    Just a flat workbench for the most part. I will use an old SLAs placed strategically inside if I need to keep a ship over on it's side while I work on it. I've also got a few foam blocks from various packages that can be used to help prop them up as well if the hull likes to rock.
  7. Wolcott27645
    Wolcott27645 Member
    North Carolina
    I have a 4'x8' assembly table with my table saw inset so I have lots of feed out. I was thinking of using my cornhole bags to help prop it up since its not nice enough to play right now!
