stokamoto USS MISSOURI
Discussion in 'Warship Builds' started by CURT, Mar 14, 2011.
  1. bb26
    How much clearance do you have from the top of your batteries to the sub deck?
    Rudder servo mount and servo. Test fitting
  3. bb26
    Looking good so far
    I can fit Dean's Connectors with room to spare. :)
  5. bb26
    I might have to go that way for the batteries. I think it will be a tight fit on the Tennessee.
    You will have room if you go this route.
  7. Jay Jennings
    Very nice Curt! I like what I see, can't wait to see it on the water.
    That may happen sometime in May Jay at least early June for sea trials.
    Some more work done on the Mo this weekend. Iowa's Captain worked on the wing struts and installation of a pair of dual sidemounts for fitting. We worked on the funnel Caps but those things are driving me nuts.
    Rudder servo mount is waterproofed.
    Closer look of the rudder servo mount with servo
    Throttle servo in the mount with the throttle swtiches. The switches are held in place by brass pins. They can easily be removed for replacement.
    Both Throttle Servo Mount and Rudder Servo mount
    Iowa and Missouri progressing along well.
    A lot of Balsa blocks abound. Mostly failed shapes.
    Tom taking measurements off the plans.
    Finally got both Funnel caps made correctly or at least close to it. The main Control tower is finished too. I will be working on the Superstructure this week and hope to begin sheeting in an week or 2.
  11. CURT
    More work was done today. I'll post them weekend sometime.
  12. Jay Jennings
    Lookin good Curt!
  13. Miller7D
    Miller7D Member
    I am so jealous of your superstructure. Nicely done!
  14. NASAAN101
    Curt,
    What kind of foam are you using???
  15. KeriMorgret
    Seattle, Washington
    Nikki, it looks like he's using the foam from us at Strike Models. It's foam we bought form the manufacturer in Los Angeles then had cut to the various thicknesses that we need.
  16. djranier
    Keri
    The other day when I was talking to Stephen I should of asked him. Do you sell like 1x2 ft peices of it at 5/8 thick, or jsut the precut SS stuff?
  17. NASAAN101
    Keri,
    I was a an army surplus store and found the foam there, but i dont know how well that would stand up to BB's???
  18. KeriMorgret
    Seattle, Washington
    Djranier -- I'll ask and see.
    Nikki -- I have no idea. There are many, many different types of foam. We get stuff that's close, then we test it by firing a bunch of rounds into it.
  19. CURT
    This foam holds up very well. My Bismarck at Nats contained all of the original holes from 7 yrs of hard fighting with Nabs. It was repaired first time in 1999. Then from there it went unrepaired absorbing hundreds of more bbs and again many thousands more at 2010 IRCWCC NATS. I since have a new superstructure package from Strike to use as a show boat structure and keep the original for battling only. The foam is easy to work with. I find it very durable, takes paint pretty good and you can sheet it with styrene or protect it with termite armour.
  20. CURT
    I removed the rear structure I had made the other day. I forgot that it narrows towards the top so I made another one.
    This piece of structure at the top was very confusing indeed. The plan shows it as a round cylinder yet looking at other Missouri models such as the 1/96 build on the site Warship models underway I was able to see the structure clearly before the detail clutter was attached. It shows it similiar in shape to the larger section of the conning tower beneath the uppler platform. I find the plans are not very accurate in the drawings of the items represented such as the shape of the gun tubs on the main turrets and AAA platform near the rear stack. On the drawing thier drawn as circles only but looking at the models and photos they are cleary not. So I will correct this . Making adustments as I go.
    port side foward supestructure and conning tower.
    The aft tower is the first one I made before I spotted the error.
    Making progress. This and a wedding coming up in a few weeks. TRYINGo_O to get as much done before I say "I DO". :crying:
