Off Market STYNGER MAX Hard Hitting, Fast Shooting Cannon
Discussion in 'Buy, Sell and Trade' started by SteveT44, Sep 22, 2017.
  1. jadfer
  2. Sinkazuki
    Sinkazuki Active Member
    Colorado
    Steve, do you sell drilled pistons separately?
    Randy
  3. Beaver
    Use plastic pistons and drill them yourself. ;)
  4. SteveT44
    Maybe. PM me your piston dimensions and quantity and I'll quote a price.
  5. Sinkazuki
    Colorado
    Steve, I don't have your contact info.
    My pistons are probably the same ss you use.
    5 mm shaft width about 15 mm long.
    Base is not important as it will be cut down.
  6. SteveT44
    Randy, you can PM me though this forum, just click on "Start a Conversation" under my avatar pic. Length is important. I bore most of the way through with a 3mm bit and then finish it off with a smaller bit. Trying to bore with the smaller bits results in to much bit breakage.
  7. Anvil_x
    Those..... oh boy.... oh that's nice....
    Hey so drooling aside, if you were to build a custom set for a specific application, what sort of measurements would you need? I'm starting a major refit on an old hull and am thinking of doing something that will require at least a pair of specially-built guns (I'm turning into a neat-freak and this particular spot in the hull is pretty cramped atm) with a lot of power behind them .
    it wouldn't be for another six to eight months, but what should I keep in mind as I do the refit?
  8. SteveT44
    You could give me a drawing of the cannon outline (or the build envelope) and I could build to that. For power, the longer the uptube and barrel, the more power you will have.
  9. Anvil_x
    okay cool. I'll see what I can crank out on Fusion 360 when I get to that point
  10. Beaver
    So do these have to be sent back to the manufacturer for maintenance or repair since they seem to be entirely glued together? ;)
  11. SteveT44
    Tyng Tech has some of the best time and material rates in the industry. Of course, extended warranty plans are available! ;)
    All kidding aside, the piston cap will come of easily enough (blue Loctite) for access to the internals.
  12. Lou
    paypal?
  13. SteveT44
    Yep
  14. NASAAN101
    Steve. Do you take cash??
  15. SteveT44
    Check, money order, or PayPal.
  16. NASAAN101
    Cool.
  17. Beaver
    Nikki, these guns won't make your boat any better if it's still on the bench. ;)
    Panzer likes this.
  18. NASAAN101
    All i have to say to that is :p:p:p:p
  19. Beaver
    Ok, :p to you too!
  20. NASAAN101
    We would have fun hanging out at a battle.
